Mtl_Biker
(My Flat Tire Help thread had over 100 views, but not a single comment or suggestion. So I'm trying a more focused - on the problem - thread.)
How should you mount a tubeless tire onto a tubeless rim (my first time)? Am I missing a step or something?
I got the tire onto the rim alright, and using a strong floor pump, pumped the tire up so that I'm pretty sure the bead was set all around. But air seeps out the edge where the bead meets the rim. So quickly that you can actually hear and feel it. The bead looks and feels like it's properly set. How much air pressure should be filled in to seat the bead properly? I'm assuming more than the normal riding pressure.
What am I missing?
Do you use any product on the bead of the tire when mounting? Both to lubricate it and thus make it easier to "seat" and also to make a better seal? I found something online that suggested that you really must put your sealant in right after mounting the tire so that it will help seal the bead, but gee, if there's another problem with the seal that would make a real mess if you have to unmount and then remount the tire. Another comment I saw was that after installing tubeless you shouldn't (nor could you) ride the wheel for about two days. Surely that can't be right? They suggested it takes that long for a good seal to be made and air leaks to stop. I mean car and motorcycle tubeless tires can be ridden immediately after installation. What's different here?
Thanks for any help!
What am I missing?
