mrgold35
- USA
- City
- ABQ, New Mexico
It doesn't seem flats resistant tires for fat bikes are not on the market yet. All kinds of tire choices with regular and plus size (e)bikes. I have two his/hers 700X40c pedal bike since 2014 with Mr. Tuffy+Stans and I never had a flat with either bikes. I seem to having equally good luck with the plus size tires on the Radcity Step-Thru with Mr. Tuffy+Stans on the same routes as my old pedal bikes.
It was just days into ownership before getting a flat with my fat tire ebike (no Mr. Tuffy of Stans yet). Between both fat ebikes I've had since 2016 and +6000 miles; I've gone through 6 tires (4 worn, 2 destroyed by road debris), will need 4 new tires by next summer, and around 10-12 tubes. Sometimes it is easier to replace the tube instead of trying to patch 5-10 goathead thorn holes if I hit a bad patch.
I would rate regular/plus size tires in the excellent range for flats compared to fat tires in the poor-slightly below average in the same environments.
You might be A-OK with Mr. Tuffy+Stans+Tube for added layer of protection on the ebike if you ride a regular bike a lot and haven't had issues with flats.
