Nirmala
Another email and another delay:
Hello ShareRoller Indiegogo backer:
Now that August has arrived, we wanted to share a quick update, as we know you are more than ready for your ShareRoller(s) to arrive. We continue to get closer to assembly kick-off, with 4 of 7 key supplier sub-components now received or shipped, and 2 in final supplier production testing. But unfortunately our battery packs have been delayed another month, as production sample testing revealed further weatherproofing requirements for an IP54 rating (see below for detail).
We do expect to begin assembly of the main motor modules this month, but the battery packs will now delay shipment until September. We're terribly sorry to keep you waiting longer, but we absolutely want to be sure ShareRoller's battery packs can stand up to any amount of rainy weather!
On a more positive note, in preparation for our production launch we have moved into a much larger assembly facility here in lower Manhattan. This new space will allow us to both expand the ShareRoller Team and to produce the significantly higher volumes we hope ShareRoller will achieve once full launch occurs. It's a very exciting step for ShareRoller and we look forward to sharing photos of the new space soon!
And for those who want to read further, here is additional detail below on all key subcomponents:
The issue with waterproofing had to do with the joint between the top and bottom halves of the battery pack shell. Initially our supplier felt we could meet IP5X level waterproofing without a rubber seal between the shells, but testing proved otherwise. So we had to design the custom seal below, and have another mold made to produce the seal, which takes several weeks, hence the one month delay.
At least with the rubber seal in place, the battery packs should have no trouble exceeding the IP54 standards, meaning you'll never have any problems riding in the rain.
Again, we're terribly sorry for these further delays and we really wish there were some way we could deliver sooner. Fortunately, we continue to get closer and closer to the goal (despite the fact that the goalposts keep moving on us!), and we're confident the ShareRoller SR4 we finally deliver will far exceed all expectations.
Thank you again for your patience and support.
Jeff Guida & The ShareRoller Team
- Drive Motors: Our supplier has completed and shipped the first production run of our incredible custom Drive Motors. Since we managed to incorporate a few performance enhancements vs our earlier production samples (slightly thicker magnets for one), we can't wait to test out the optimized production version!
- Heatsinks: With our diecast molds complete, our supplier has manufactured and shipped the first production run of our heatsink set (shown below is the smaller of the pair).
- Gearmotors: Our custom designed ultra-high torque gearmotors+encoders have been received and are awaiting assembly here in our new space.
- Retracting battery cables: We had to make a small unexpected change to the tooling last month, but that is now complete and the final plastic shells are in production (samples below). Assembly and shipment of our first production run should be complete within 2 weeks.
- Wireless throttles: Since we had the time, we made one last change to a button position on the custom PCB, and expect to receive our production batch before the end of the month. We'll share pictures of our ultra-versatile and ultra-functional throttle design then.
- PCBs: We had to make a few more tweaks to the design before doing a volume run, but still expect to receive production units before the end of the month.
- Battery Packs: Below is a picture of a production prototype pack being assembled by our supplier - the BMS board has yet to be installed, hence the gap between the cells and the retracting battery cable (also a sample).
