johnwebike
- USA
Love to see more about your bike build. Where did you buy everything? Did you do a website or youtube of your build?I went ahead and built my own ebike.
X3 Pro great value and performance for the price, but I needed a bit more.
I no longer own it.
Settled on this build:
Summary 26" Fatbike, aluminum frame, 1500w hub motor, 48V 30AH pack, 34MPH top speed on flat ground.
It took me 45 days to build and dial-in. I did my first 30-mile off-road trip today. Loved it.
Frame: Framed Minnesota 2.0 18". 175mm ODA rear hub Front Fork: Bolany fat Air 135mm Straight Headset 28.6mm fork, ZS44 (44mm press fit cup) Fork headset spacer set Handlebar: Seat post/clamp 30.9mmx400mm Seat Motor: Bafang RMG062 1000W 48V CST Geared motor: Controller: 1500w/60v Battery 21700 cells: QB27100 x 72 Battery cell spacers 20x13P honeycomb 21700 2x 15x15" aluminum plates for ebike triangle box build .5x.5 1/16th aluminum angle 8-feet Nickel Strip Tab 0.15mm x 22.7mm offset 12V regulator for ebike lighting, USB charger, power meter Front Rim 26" 32H 80mm Front Spokes kit Front wheel hub Rear Rim 26" 36H 80mm Rear Spoke kit Rear 8SP cassette 8 speed SRAM SP-830 chain 8-Speed Rear Derailleur Schmimano Altus Bottom Bracket 100mm SRAM GXP 2X tires 26x4 Rotors 203mm front (and 203mm IS adapter), 160mm back Hydraulic brake set 2x tubes 26x4 TOTAL Price.
Thanks for the inspiration. I may do the same after the Wallke experience im having.
