The evolo aurora at least has a serious looking rear shelf and fenders. Drop frame is nice past age 60; I lost a lot of muscle stretch there but not any strength.
The new harmony 380 has some internal lubricant which sometimes leaks out, and people here have reported software errors. Lubricant may thicken up in winter. As it is made in Texas I wish you all the luck in the world. Been thinking about one. Shimano Index shifting put a 2" dia. cyst above my thumb joint, and a twist shifter is so stiff it takes gloves to make it downshift when wet.
I found in going from shimano 7 spd derailleur mtn bike to Sturmey Archer 8 speed internal gear hub (same bike), I lost 20 minutes on my 30 mile commute to the country. Hopefully the electric motor will make any IGH drag invisible to you.
95 rpm, wow. I do about 70 except on steep hills. And I'm only 8 years older than you.
Here is some technical information about geared hub efficiency. I think you might want to check axle tightness.
As with other traction-type CVTs, transmission of torque through the NuVinci CVT involves some relative sliding between the torque-transmitting contact patches.
[9] This is because, for any given contact patch, parts of the ball are going in a slightly different direction and at slightly different speeds than the disc (this
phenomenon of traction-type CVTs is referred to as "contact spin").
"The spin velocity (or drill speed) is defined as the difference in the rotational speed of the driving and driven rollers in a direction perpendicular to the contact patch plane.
It is caused by the relative difference in surface speeds of both elements across the contact patch and is a
major source of power loss in traction drive CVT’s."
[9]
In all traction-type CVTs, this relative sliding necessarily occurs between surfaces which are under the very high clamping pressures required to ensure torques are transmitted reliably.
This relative sliding under high pressures cause transmission losses (inefficiency). Fallbrook Technology refuse to publish any efficiency data for the NuVinci CVT.[10]
However, the NuVinci is a variant on the "Tilting-ball drive" type of continuously variable transmission (CVT), and
the efficiency of "Tilting-ball drive" type CVTs is typically in the range of 70% to 89%.[11]
However, its geometry does differ significantly from the Kopp type of tilting ball variator in the reference in that the NuVinci has its torque transfer contacts on the outside diameter rather than the inside diameter, which puts the idler (an element that reacts clamping load) in compression rather than tension, and because the idler contact surface is not conformal as in the Kopp design.
In general because of the way the CVT is set up, it
is more efficient at a 1:1 ratio compared to maximum overdrive or underdrive positions. Independent test results have shown that at 1:1 it is actually more efficient than comparable bicycle internal gear hubs, while at the ratio extremes it is slightly lower.[
citation needed]
Their biggest advantage is the durability, while shifting under load and continuously, which is especially important with the powerful eBike drive systems.
https://en.m.wikipedia.org/wiki/NuVinci_Continuously_Variable_Transmission
https://en.m.wikipedia.org/wiki/Continuously_variable_transmission
A belt-driven design offers approximately 88% efficiency,
[1] which, while lower than that of a manual transmission, can be offset by lower production cost and by enabling the
engine to run at its most efficient speed for a range of output speeds.
When power is more important than economy, the ratio of the CVT can be changed to allow the engine to turn at the RPM at which it produces greatest power. This is typically higher than the RPM that achieves peak efficiency.
In
low-mass low-torque applications (such as motor scooters) a belt-driven CVT also offers ease of use and mechanical simplicity.
Simple rubber belt (non-stretching fixed circumference manufactured using various highly durable and flexible materials) CVTs are commonly used in small motorized vehicles, where their mechanical simplicity and ease of use outweigh their comparative inefficiency. Nearly all snowmobiles, utility vehicles, golf carts and motor scooters use CVTs, typically the rubber belt or variable pulley variety. Many small tractors and self-propelled mowers for home and garden also use simple rubber belt CVT. Hydrostatic systems are more common on the larger units—the walk-behind self-propelled mowers are of the slipping belt variety.
Toroidal or roller-based (Extroid)Edit
Toroidal CVTs are made up of discs and rollers that transmit power between the discs. The discs can be pictured as two almost conical parts, point to point, with the sides dished such that the two parts could fill the central hole of a
torus. One disc is the input, and the other is the output. Between the discs are rollers which vary the ratio and which transfer power from one side to the other. When the roller's axis is perpendicular to the axis of the near-conical parts, it contacts the near-conical parts at same-diameter locations and thus gives a 1:1 gear ratio. The roller can be moved along the axis of the near-conical parts, changing angle as needed to maintain contact. This will cause the roller to contact the near-conical parts at varying and distinct diameters, giving a gear ratio of something other than 1:1. Systems may be partial or full toroidal. Full toroidal systems are the most efficient design while partial toroidals may still require a torque converter, and hence lose efficiency.
Some toroidal systems are also infinitely variable, and the direction of thrust can be reversed within the CVT.
[8]
Diagrams:
Examples:
