sore knee bike ride
- Canada
What would be the difference in performance between a:
350 watt 36 volt e bike
And a
350 watt 48 volt e bike
In terms of acceleration
And
Torque vs rpm?
36 volts would be around 10 amps
And 48 volts would be around 6.5 amps
I guess maybe the magnet wire would be thinner in the 48 volt motor as amps are less with the same wattage
Thinner wire might energize faster causing a magnetic field to increase faster resulting in more low end torque.
As for the speed of the stationary part of the motor, I theorize that the 36 volt might create a stronger magnetic field as there is a greater number of electrons flowing in the wire but might take longer to energize
The thinner wire might energize faster but create a weaker magnetic field
And a
And
Torque vs rpm?
