Wanted: Lightweight (less than 20kg), high Torque (90NM), Motor offering large amount of power 500w+, removable large battery
Agreed. My previous ride, a 35 nm 250W Evo Cross (detuned from 350W for compliance), shot me up most hills with aplomb at the UK legal limit.
HI PMcdonald, I don't know the Dapu motor bike i tried atn Ezego commute int which was 45nm and this didn't feel enough for me on the steep hills. I think I do need something around the 70+nm mark (like the Focus but with more power).
I agree the Dapu would have struggled on steep, steep hills. Specs sometimes belie performance though, and often on these forums I see a fixation on torque or engine output wattages that don't necessarily bear out in real life, particularly with our low legal limits. There's a limit to how informed your decision can be based on research alone.
It's good and I think appropriate to do as much background research as possible when dropping these large sums of money. But ultimately it'll be test rides that settle the decision for you. I, and many others here, encourage you to ride as many different models as possible. Some retailers will even let you have two or three day loans of bikes, which are great ways to get to know a bike before purchasing.
It weighs 20 kg with the battery but she already said she does not want dropped bars.
I know I can lift 13kg, (14kg at a push) but i injured my back and arm so can't manage much more. The problem is as well as wanting to get up very steep hills and wanting a powerful motor/ torque I have very steep steps to my house approx (45 degrees) and struggled to push bike even my light bike up this gradient. I tried a walk assist on a 20kg ezego which cut out and I couldn't manage that weight:-((
Thanks pmcdonald. It's been quite hard finding bike shops who will allow test rides let alone have stock in or are prepared to order anything in unless you commit to buying it without a test ride. I understand this policy but hate it and there's no way I can buy something like this without riding it first. If i'd done that i'd be stuck with several ebikes that weren't suitable for me. Where are you based? I'm in Brighton. I've made a comparison table based on my experiences and research so far but as you say, nothing will be as helpful as trying them out.
Like I said remove the battery before lifting.
Thanks Steve, I don't see where you can remove the battery on their website, and thus the weight of the bike without it. If the powerpack battery comes off it would help. I will write to them tomorrow and ask and also see if they do flat handlebars. This bike seems very similar to the Focus paralane2 which is also dropdown and was lovely to ride but I felt I would need more power up the steep hills. It is 60nm.
That's a shame re: lack of test ride options. I had a similar experience (Newcastle, Australia btw). My shortlist ran to about 8 bikes. Available local options quickly whittled it down to 3. Luckily one of the three worked out perfectly.
What's on your shortlist table?
I hope you find what you need Aneesa. For reference my wife is 68 and can climb a 1500 metre mountain on her 75 Nm mid- drive bike. She may even be able to do it with a 60 Nm bike but I would not want her to try with less than that.
Not so much a short list as what i've discovered. I think if I had to settle it'd be a flat bar version of the focus at 60nm but the trouble is I know i'm not happy enough with that. I loved the Trek powerfly most but it's too heavy. Here's what I've found so far...
Specialised Vado SL5 - EQ
£3499 with Rack, lights, mudguards, suspension (end Aug)
240W Power
35NM:-(
14kg
Specialised levo
560 watts of power
90 Nm of torque
19.9kg or 20.5kg
Focus
250Whrs
60nm motor Fazua
250w
output - same as vado SL
Fazua motor
15kg (wx battery = 12kg)
Ribble
40nm
250w
14.5kg
Boardman adventure
16kg
250w Fazua
mid drive motor
NM?
Trek Alliant
250 watt
75 Nm
21.5kg :-(
20 mph
Dual sport - small front suspension
motor is more powerful than vado but heavier
500whr battery
50NM
250W
Bosch motor
£2900 (kickstand)
20kg?
Trek powerfly
250Watt
75Nm
24kg:-(
Fantic
26kg!! :-(
90nm
Brose motor
625wh battery
Haibike new
120nm
27kg!
Cube Acid
65nm
23.1kg
500w battery
Alchemy
60nm
250w
Moustache
65nm
250w
500w
20.2kg:-(
Bosch
Ezego
19kg :-(
250W Motor
45NM:-(
Creo (drop handlebar) and SL x2
240w of energy
Levo?
I still think what you want doesn’t exist for the budget as evidenced by the number of responses on this thread.
I think you will need to make compromises. Really think about the must haves vs nice to haves and focus on the must have requirements that is a subset of your original requirements. That should help you narrow your choices and also get realistic recommendations. Otherwise, everyone here will be continuing to search for a pink unicorn.
You have to understand that some of your requirements are contradictory with current technology. For example, you want one of the lightest ebikes in the world but with high powered battery and high torque motor. There are fundamental reasons why ebikes are much heavier than analog bikes. They are the weight of the motor and the weight of the battery. But due to your injuries, it sounded like you are struggling even with analog bike. Are you planning on leaving the battery and panniers on the ground outside where someone can steal them while you carry your bike up?
You have to understand that some of your requirements are contradictory with current technology. For example, you want one of the lightest ebikes in the world but with high powered battery and high torque motor. There are fundamental reasons why ebikes are much heavier than analog bikes. They are the weight of the motor and the weight of the battery. But due to your injuries, it sounded like you are struggling even with analog bike. Are you planning on leaving the battery and panniers on the ground outside where some can steal them while you carry your bike up?
240W Power
35NM:-(
14kg
Specialised levo
560 watts of power
90 Nm of torque
19.9kg or 20.5kg
Focus
250Whrs
60nm motor Fazua
250w
Fazua motor
Ribble
40nm
250w
14.5kg
Boardman adventure
16kg
250w Fazua
mid drive motor
NM?
Trek Alliant
250 watt
75 Nm
21.5kg :-(
20 mph
500whr battery
50NM
250W
Bosch motor
£2900 (kickstand)
20kg?
Trek powerfly
250Watt
75Nm
24kg:-(
Fantic
26kg!! :-(
90nm
Brose motor
625wh battery
Haibike new
120nm
27kg!
Cube Acid
65nm
23.1kg
500w battery
Alchemy
60nm
250w
Moustache
65nm
250w
500w
20.2kg:-(
Bosch
Ezego
19kg :-(
250W Motor
45NM:-(
240w of energy
Levo?
Yes my wife has the Powerfly 5 and loves it ,but she almost never has to lift it because I do it for her.
I don't think so. You could get lightweight MTB mudguards but forget about the rear rack (dropper seat post and long-travel full suspension make it almost impossible). Additionally, removing the battery in the Levo is not that simple (you use an Allen key to unlock the battery from the bottom). As perfect as the Levo is, it is not a commuter bike.
I'd may recommend waiting for the Vado SL when it becomes available for the demo ride. It meets your criteria of weight and commuter equipment. The battery is not removable but given the bike's weight it poses no problem. The price is very attractive. The point you contest is relatively small torque figure and relatively small battery. Yet you don't know how this e-bike really behaves before you have tried it out yourself.
I had no patience to read the whole thread but I wonder how really steep your hills are and for what distance. I don't know how fit your legs are. Still, you might be positively surprised, especially as the Vado SL has the 1x12 drive-train meant the motor and the driver complement each other and contribute with the power. The extender "bottle" battery is readily removable.
Perhaps that's the only choice for you.
This is the truth ... a pink unicorn. ;) The EBR community has offered over a dozen choices so far...
