Ebiker01
Not so much a short list as what i've discovered. I think if I had to settle it'd be a flat bar version of the focus at 60nm but the trouble is I know i'm not happy enough with that. I loved the Trek powerfly most but it's too heavy. Here's what I've found so far...
Specialised Vado SL5 - EQ
£3499 with Rack, lights, mudguards, suspension (end Aug)
240W Power
35NM:-(
14kg
Specialised levo
560 watts of power
90 Nm of torque
19.9kg or 20.5kg
Focus
250Whrs
60nm motor Fazua
250w output - same as vado SL
Fazua motor
15kg (wx battery = 12kg)
Ribble
40nm
250w
14.5kg
Boardman adventure
16kg
250w Fazua
mid drive motor
NM?
Trek Alliant
250 watt
75 Nm
21.5kg :-(
20 mph
Dual sport - small front suspension
motor is more powerful than vado but heavier
500whr battery
50NM
250W
Bosch motor
£2900 (kickstand)
20kg?
Trek powerfly
250Watt
75Nm
24kg:-(
Fantic
26kg!! :-(
90nm
Brose motor
625wh battery
Haibike new
120nm
27kg!
Cube Acid
65nm
23.1kg
500w battery
Alchemy
60nm
250w
Moustache
65nm
250w
500w
20.2kg:-(
Bosch
Ezego
19kg :-(
250W Motor
45NM:-(
Creo (drop handlebar) and SL x2
240w of energy
Levo?
Levo is great.
What Haibike is that with 120nm ?
If it's the Flyon with TQ motor then that should be nr. 1 to get. Is a lot of power and that motor is the BEST. The xtra weight is nothing for 120nm.
Is like having 2 Trek Bosch motors in one ebike
Does the Bianchi Ttronik takes rear rack +fenders ? then that is another good option.
But from what i know the Haibike Flyon , it was not avlb. Maybe it is where you are ?? Get that one if so..
Another good one is Greyp G6 . Google it.
