The protection plan is through Allstate. NOT Walmart.
20% of Allstate reviewers rated the coverage as poor.
Good luck with this one. Lawyer up...
8. WHAT IS NOT COVERED: A. ALL PROTECTION PLANS: (A) Except as otherwise provided, normal wear and tear; (B) Any and all pre-existing conditions that occur prior to the Coverage Start Date of this Protection Plan; (C) Natural flaws or inherent design or manufacturer’s defects; (D) Intentional damage; (E) Lost, stolen or irretrievable items; (F) Any Product that is fraudulently described or materially misrepresented; (G) Secondary or collateral damage; (H) Except as otherwise provided, maintenance, service, repair or replacement necessitated by loss or damage resulting from any cause other than normal use, storage and operation of the Product in accordance with the manufacturer’s specifications and owner’s manual; (I) Damage caused by exposure to weather conditions, improper electrical/power supply, improper equipment modifications, add-on products or accessories, attachments or installation or assembly, collision with any other object, vandalism, animal or insect infestation, corrosion, battery leakage, act of nature (any accident caused or produced by any physical cause which cannot be foreseen or prevented, such as storms, perils of the sea, tornadoes, hurricanes, floods and earthquakes) or any other force majeure or peril originating from outside the Product; (J) Damage caused by “accumulation,” including, without limitation, damage from any repeated use or gradual buildup of dirt, dust, oils or similar, such as hair and body oils, perspiration or darkened bodily contact areas; (K) Damage caused by: any improper care, negligence, neglect, intentional acts, misuse or abuse of the Product; any repair, replacement or handling of the Product other than as recommended or authorized by the manufacturer and/or Us; or any failure to comply with the manufacturer’s warranty; (I) Damage caused by cleaning methods, products or materials; (M) Defects due to the installation, assembly or hookup of Your Product; (N) Damage caused by transit, delivery, redelivery, removal or reinstallation of the Product, or the Product being moved between different locations or into or out of storage, including damage caused by packing or unpacking of the Product; (O) Claims made under any improperly or incorrectly purchased Protection Plan; (P) Except as otherwise provided, “cosmetic damage,” defined as any damages or changes to the physical appearance of a Product that does not impede or hinder its normal operating function as determined by Us, such as scratches, abrasions, peelings, dents, kinks, changes in color, texture or finish, or similar conditions; (Q) Television or personal computer monitor screen imperfections, including “burn-in” or burned CRT phosphor; (R) Accidental damage or liquid damage unless ADH coverage was offered and purchased as part of Your Protection Plan; (S) Projector or rear projection TV bulbs; (T) Consumer replaceable or consumable batteries unless battery coverage has been offered and purchased as part of Your Protection Plan; (U) Consumer replaceable or consumable items including but not limited to toner, ribbons,
