There is like the advantage the Sur-Ron has...it can have a final drive gear ratio that amplifies the torque even at the faster speeds because it's not an ebike. I remember the Izip Express separated the mid drive system and the human system so both could be optimized but that pretty much means there must two independent drive systems (one on each side of the rear wheel).
interesting to hear about the izip express. separate systems makes a lot more sense, illustrated below.
on the sur-ron, they're basically taking advantage of the e-bike laws to deliver you something via export regulations that are designed for ebikes, which are themselves a part-way-hangover from when scooters didn't have a kickstart or a motor, and you had to pedal the scooter for a few feet in order to get it started
so you get a 3kW motor with a cable attached that strangles the power to 500W, a rear sprocket with 25 teeth on it, a set of pedals with another 25-tooth sprocket on it and a one-way ratchet (yes, 1-to-1 pedalling), and a pair of incredibly dangerous e-brake switches, just so the exporters can slap an "e-bike" label on the customs forms.
when it arrives, you cut that cable (which immediately removes the 500W limit), remove the pedals, put a 61-tooth sprocket on the back and you're up to 75km/h with the stock controller (we can do 110 km/h
). of course, with the e-brake cut-off switches, you hold the brakes (even just touching them lightly is enough), twist the throttle and nothing happens. you sit there, puzzled, and your hand twitches ever so slightly - enough to "let loose" that ultra-dangerous e-brake switch.
result: the bike launches away from you, pulls your arms out their sockets which of course causes your fingers to twist the throttle even further and from that point you're in real trouble unless you have extremely strong wrist muscles. if not: the front wheel goes straight in the air, your feet slip off the stands, and you smash into the nearest object in front of you. the *very* first thing i did was cut those incredibly stupid e-brake cut-off switches on my e-bike. they're absolutely lethal. i cannot believe the stupidity of the EU regulators who thought they were even remotely a good idea.
anyway, back to the point: if you have powerful drivetrains like this, there's just no way you can integrate pedals into the (exact same) drivetrain in any mechanically-meaningful way.
it therefore just makes a huge amount of sense to me to have two separate drivetrains:
* one with a small sprocket on the motor and a large sprocket on the wheel (like a motorcycle)
* one for pedals with a *large* sprocket then a small sprocket on the wheel (like a bicycle).
i "get" why people like the mid-drive systems, because you can integrate the two into one. it looks... "neater". however... the forces (torque) involved, in such a small space, and to put chains under more force to get those kinds of 50+ km/h speeds? as an engineer i'm actually quite alarmed to hear that's what's being done.
although it sounds weird to have double sprockets on the rear wheel *and* double chains, mechanically it is better matched, and there will, ultimately, be far less wear and tear on the whole e-bike.
so let's take a look at what izip express did:
yep, there you go: you can see a standard derailer on one side, then i *think* it's... a belt drive on the far side, is that right? it almost looks like the drive wheel is touching the back wheel, just like those old french scooters (you've seen "Mr Bean's Holiday"?) but no, it's a separate chain/belt. yeah, that's a really good idea.
