Hey folks,
I could use some help deciding between two similar, but also very different 45km/h bikes: the Trek Allant+ 9S (625Wh) and the Stromer St2 (821Wh). I ride 2x11km daily on mostly flat asphalt, with often wind but with not many stops.
Price-wise the two are similar and have common specs: Gates carbon belt drive, inside gears, side-removable battery, hydraulic two-piston brakes, same size wheels and high volume tires.
What the Trek has for it:
- front suspension fork (though I tend to ride with locked fork so as not to wear it out on decent asphalt)
- easier to find repair shops as Bosch engine is popular
- 8% lighter
What the Stromer has for it:
- very quiet motor
- embedded display with GPS tracking and SIM card, smartphone connectivity, lock
- keyless release battery
- a bit more efficient engine than Bosch?
- 25% more range
Which one would you go for and why folks? Looking forward to any advice you have. Thank you!
- 8% lighter
- very quiet motor
- 25% more range
