I have a recent model (not sure of year) E-motion Street. I have found the PAS doesn't work well for me because I have a weak right leg which messes with the assist. I switched to using the half grip throttle. It is still really jumpy on a full charge but evens out as the battery drains a bit. Still better than the PAS. Anyway, my wrist begins to ache from holding the throttle after a while. I added a wire tie to the grip to use it as a thumb throttle, but now my thumb is cramping. I think the problem is with the spring resistance in the throttle. I'd like to make it super easy to twist so it takes very little pressure to keep it steady. Are there differences in the spring tension (I assume there is a spring involved??) between different throttle brands? Is there a way to modify the one I have to twist more easily?
Thanks!
Thanks!
