Just bought a Turbo Vado 5.0 SL non EQ.
VERY addictive unlike my "normal" pedal bike.
I know you all know all this but I had no idea as I "assumed" buying an e'bike was a resignation to a less active riding life at age 66.
Of course I was wrong.
I can get up a steep series of nearby hills good riders struggle with on $10,000 race bikes that I tried once back in the day and gave up half way and never bothered again.
The interesting thing is because you pretty much know you can make it you make the extra effort despite the assist and in effect I am working harder and attacking different leg muscles/thigh muscles than I do on my regular bike where I pretty much say, "screw the hills, I'm sticking to the flats."
Even on flat ground I'm finding I'm working harder as I'm going 50+ percent faster with the same effort depending on the mode.
12 mph as a "normal" comfy pace becomes 18 mph and pushing it goes from 15-20 to 20-30 so you end up pushing it more often.
I think I'll be getting more of a workout on this thing by far than the other bike which is not at all what I was expecting as I feared I'd just take it easy and let the bike do most of the work.
Both bikes weigh the same, as my Kona Nunu, a Mountain Bike now riding on Hybrid Tires at a bit over 30 lbs is a bit porky. For an E'bike 33 lbs is very light and the aluminum frame and carbon fiber fork give it a far more nimble/lighter feel.
Even with no assist the E'bike, with its superior components, is easier to pedal and glides easier/faster downhill, so zero range anxiety and no need to buy the optional extender battery for me.
The speed is the reward on the E'bike though.
Very very odd.
I can see having a lot of fun in the hills above my house where traffic is light and where I never ever ventured before because I didn't want to struggle up them.
That was my hope.
So, despite being quite expensive, (you can buy one heck of a great A/V system for 5 grand), I think it is great value for me as I will actually be getting more exercise than ever and at age 66 that is priceless.
And a small part of it is that riding without my riding partner of many years, (who I had an idiotic falling out with after decades), who was always slower, does indeed allow me to push more, so there is that.
Since the photo I've added a bar end mirror and kickstand.
I've always taken kickstands off but this one is too nice to just drop on the ground or lean against a tree.
Very very odd.
That was my hope.
Congratulations on your new favorite bike. When I bought my SL I equated the 'mode' switch on the handlebar with effort. If I needed help - press it. But I was so wrong. Really, for me anyway, it's a speed switch. And that's because having an SL has never reduced my effort. I'm still cranking out the same watts no matter the assistance and when I go from eco-sport-turbo, I just go faster. I love it. The SL is a bikers e-bike. That's the best thing about it.
It was a revelation to me though a well known fact on this forum.
I'm guessing the only improvement to the bike in the next year or two will be a carbon version which is certainly not something I'd trade in this bike for.
The "invisible" Futureshock is something I wanted and for me it works perfectly for my kind of riding.
How the derailleur gets the chain onto that biggest rear cog remains a mystery of engineering to me but it gets up there no problem.
Anyone upgrading/upgraded their Sram GX derailleur to AXS? Seems like they are on sale at a few places right now for $420. Ordered it and should be getting next week. Also ordered an upgraded paddle shifter for $20.
Wondering if there is any way of powering the derailleur off the main battery?
I emailed Sram to ask if the derailleur would work, and they said yes, AXS eagle GX is a direct replacement for regular eagle GX. They also said it was unusual that Specialized used an 11 speed front chainring with a 12-speed rear derailleur. (Gave them specs from the Specialized website)
IDK, the derailleur works perfectly on my bike, why are you "upgrading"?
I am thinking of swapping out the pedals for metal ones so I can add toe clips.
Nerd factor 😃 faster/more accurate shifting. Less cables? Bored because it's too cold to ride and not enough snow to ski yet? 😃
  • Like
Reactions: GAJ
Ah, ok, I thought there might be a more technical reason or some design flaw you were trying to correct.
Hi guys, I have a bit of a problem. The bleed port screw on the rear brake caliper is rounded off so now I am unable to bleed my brakes.
The brakes have been bled only once previously by my local bike shop. It appears that during this process the Torx screw was damaged.
I'm at a loss as to what to do next. I have searched for a Tektro HD-R290 rear brake flat mount caliper to no avail.
Any suggestions? Is there a different caliper which is a straight swap?
I was able to remove a rounded bolt head by superglueing a sacrificial allen key (have plenty from furniture assembly kit). I think it is fairly common/easy for the smaller bike bolts to get rounded and there are a number of youtube videos with various methods for removing rounded bolts. In any case, you will probably want to replace the damaged bolt. I was able to get a good bolt from my lbs's random spare used parts. Have you tried seeing if Tektro's web site has spare/replacement parts available?
I've tried the supergluing trick in the past, it's never really worked for me.
The problem really is that the LBS tightened everything down too much ( the torx bolt at reservoir was so tight that the o-ring split).
I'm resigned to replacing the caliper but although I can find the part on the Tektro website, I cannot buy it direct.
I can source an HD-R280 locally but there is not enough info on the Tektro website to determine whether this is a direct replacement.
In the past I would have used a European supplier but the masterstroke of self-harm known as Brexit has scuppered this.
That's why I'm reaching out to the forum to see if :
a. anyone has the part I need lying around (I've read some have upgraded brakes) or
b. might know whether the HD-R280 (or some other caliper) can be used instead.
