Yes, the bigger battery. Do not trust the weight given by Specialized until you actually weigh the e-bike :)
IDK, they provide the weights now for both...essentially identical though. IIRC when I weighed my 5.0 non EQ using a digital bathroom scale it was 33lbs.
6.0 LTD non EQ.
Weight
14.98 kg (33 lb, 0.4 oz)
Weight Size
MD
5.0 non EQ:
Weight
14.9kg (32 lb, 13.6 oz)
Weight Size
MD
6.0 LTD non EQ.
Weight
Weight Size
MD
5.0 non EQ:
Weight
Weight Size
MD
Well, the 520 Wh battery is substantially heavier than the 320 Wh one. I expect the weight difference between the both batteries being up to 3 lbs. That's exactly the carbon frame gain cancelled by the battery weight...
Does anyone know if it has UDH hanger ?
I’m surprised they went Shimano rather than SRAM for the groupset..
Yeah me two! I heard loads of rumours that they were pissed at Shimano for supplying Trek during the Covid shortages and so had switched lock stock to SRAM. Guess business is business. A good deal etc.
Yeah for sure.. I was only introduced to Specialized in 2021 and looking at their portfolio for e-bikes I thought they and SRAM were best buddies…
I don’t think the SL2 has the UDH however just zooming in on the video
Would the SRAM GX Eagle AXS Upgrade Kit fit straight on the Vado SL 5?
Sounds like a fantastic upgrade from that review. Expensive at RRP but with a discount it would be tempting.
If you search on some threads, I did this upgrade a few years ago. Love the AXS on my Vado SL. Silent, quick shifting. No adjustments needed. Just make sure the battery is charged, and/or carry a spare!
Took about 30 mins. Also, I was able to remove the derailleur cables, since it's wireless.
I think the story was the following:
During the pandemic, Shimano experienced HUGE issues (don't ask me what issues) and could not deliver components in the quantity required by Specialized. Reluctantly, Specialized turned to SRAM as SRAM could deliver at that time. Meanwhile, Shimano has recovered. If you look at the Vado SL 2 specifications, you will see the LTD has an electronic SRAM drivetrain while the 6.0 is the mechanical Shimano.
UDH or not? If Specialized wants to use either drivetrain on different e-bike models, it probably has to be the UDH.
Did you ever explore the possibility of keeping the system charged via the bikes battery?
Also, I am assuming the upgrade did not affect the warranty? 🤔
Not sure about the warranty. I didn't look at wiring it directly from the bike.
Did you attach the derailleur to where the thru axle attaches like with the UDH or did use an adapter ?
A pic would be really cool (I tried searching but failed…)
I can't remember if I attached to the existing hanger, or if the AXS came with a hanger. I think I used the existing hanger.
Help with new app issue, please: The Specialized app failed to record cadence and rider power on yesterday's ride. Yet I saw both in real time on the TCU as usual. First time that's happened.
When I exported the .FIT file to RideWithGPS, no power or cadence data showing there, either.
The app recently updated, but pretty sure that was 2-3 rides ago with no immediate fallout. Settings look fine.
Thoughts?
ADDENDUM: Ride recording back to normal on the very next ride without any meaningful intervention on my part.
One glitch I've noticed lately, starting maybe a dozen rides ago (before the recording failure above, but maybe after the most recent app update): The app sometimes starts and then closes itself a second later. The bike is generally still off at this point. Next try, everything's fine.
Follow-up: Some 20 rides later, hasn't happened again.
So I am pretty much decided that my next upgrade for my Vado SL 5 will be the Eagle AXS upgrade. In the UK the GX upgrade kit is around 400 pounds (~520 USD) but I have seen a couple of very heavily discounted XX1 upgrade kits for around 550 pounds
We all like shiny things of course, is the XX1 worth the extra over the GX if I can get it for that price? this is brand new in box with manufacturers warranty.
Thoughts?
