Selling my medium sized Watt Wagons Hydra. I paid $6,400 in June 2021 and it was delivered in late October 2021. I've put a little more than 700 miles on it since, mostly on the road. Would like to get $5000 $4750 for it.
Reason for selling is that I have almost exclusively been riding my Santa Cruz Bronson since none of my friends have ebikes. As you can see there's some dirt and a couple of scuffs here and there, but nothing major and I've given it a good cleaning since taking these pictures. About 100 miles ago I disassembled the motor and packed it with Mobil Unirex N2 grease (and a new gasket) to quiet it down a bit and promote longevity.
This is a monster of a bike, super powerful and absolutely crushes hills. Great traction on trails from the Tannus inserts which allow you to run super low pressure. Keeps up with ~30mph traffic on the road easily.
Specs:
Specs:
- Size medium
- Northern Lights Cerakote (clear coated so it's quite a bit darker)
- Matte clear frame protection on toptube, battery door, and chainstays
- Archon X1 controller upgrade with programming cable (custom tuned to 125w-750w steps with class 3 28mph limit in eco mode and unrestricted 1000w-2300w steps in sport mode)
- Modified throttle with Honeywell SS49e hall effect sensor for finer throttle control
- 52V battery (before WW switched to 48V)
- 10 amp fast charger (and a spare more portable 2 amp charger)
- DVO Diamond E2 e-bike specific fork set at 150mm with a clear protective wrap
- Manitou Mara shock
- Magura MT5e with e-bike specific levers (wired into the controller to cut power)
- 203mm Magura MDR-C rotors front and rear
- MTX Braking heavy duty e-bike brake pads
- Shimano XT M8000 11-speed derailleur/shifter
- SunRace CSMX8 11-51T cassette (with spare Shimano SLX 11-42T)
- Wolftooth Goatlink (for cassette compatibility)
- Garbaruk extended derailleur cage (again for cassette compatibility)
- 27.5x2.8" Schwalbe Nobby Nic tires
- Sun Ringle 40mm width wheels
- Tannus Armor (with tubes) front and rear
- SDG Bel Air V3 Saddle
- 170mm KS Rage-i dropper post
- PNW Loam XL Grips
- OneUp Aluminum pedals
- Protaper aluminum bars trimmed to 780mm
- Crud XL front fender
- SKS Mudrocker rear fender
