SDURO Trekking 3.0 2020
Vim Fuego
Hi, just ordered one of these from Haibike direct. They seems to have removed all these bikes from the website, and put the 2021 models on there. This is quite annoying (not that there are now 2021 models), but I can no longer see the official spec of the bike I have ordered. Looking at other websites that sell this bike, some say it comes with Intuvia, others say Purion. All I know is it's got Bosch Performance Line, 65Nm, 25km/h motor and 500W/h battery.
Anyone know for sure?
Thanks,
Google your bike with "2020" in the search and you'll most likely find the specs.
I think this what you may be looking for.
Technical Information
ENGINEBosch, Performance Line, 250 W, 65 Nm, 25 km/h
DISPLAYBosch, Intuvia
BATTERYBosch, PowerPack, 500 Wh
FRAME FAMILYHaibike, SDURO Cross/Trekking, Aluminium 6061, Quick-release 5 x 135mm, Disc brake Post Mount
FORKSR Suntour, NEX E25-LO, Lockout, Steel spring, Travel= 63 mm, Steel steerer tube 1 1/8", Quick release 100mm
CHAIN GUIDENylon directmount
CRANK ARMHaibike, Forged, Aluminium
BRAKE (FRONT)Tektro, T275, 180 mm, 2-piston disc brake
BRAKE (REAR)Tektro, T275, 160 mm, 2-piston disc brake
TUBEPresta valve
RIMRyde, Zac421, hollow rim, Aluminium
CLAMPING RINGQuick release, 34.9 mm
REAR DERAILLEURShimano, Deore M6000
SHIFT LEVERShimano, Deore M6000, Rapidfire, 10 speed
BOTTOM BRACKETintegrated in the motor
SPROCKETShimano, HG50, 11 - 42 teeth
CHAINKMC, e10S
CHAINRINGSteel, 38 teeth
BRAKE LEVERTektro, T275, Aluminium
TYRESchwalbe, Road Cruiser , 42-622, 28" x 1.60"
FRONT WHEEL HUBHaibike Components, TheHub +, 6-bolt standard
REAR WHEEL HUBHaibike Components, 6-bolt standard
SPOKESSapim, Leader, black
HANDLEBARHaibike Components, TheBar +, 720 mm
GRIPSXLC, Comfort bo3
STEMHaibike Components, The Stem +, A-head
HEADSETFeimin, A-Head Tapered, ball bearing
SADDLEHaibike Components, TheSaddle
SEAT POSTHaibike Components, The Seatpost +, Patent, 31.6 mm, Aluminium
PEDALSVP, E461, Aluminium, with Reflector
WEIGHT (KG)23.9 kg
PERMITTED TOTAL WEIGHT130.0 kg
HEADLIGHTTrelock, Bike - i Veo LS230, 20 lm
REAR LIGHTAXA, Blueline
CARRIERsystem carrier, 25.0 kg
FENDERSSKS, Chromoplastics
STANDUrsus, Mooi, Rear stand
