| ENGINE | Bosch, Performance Line, 250 W, 65 Nm, 25 km/h |
| DISPLAY | Bosch, Intuvia |
| BATTERY | Bosch, PowerPack, 500 Wh |
| FRAME FAMILY | Haibike, SDURO Cross/Trekking, Aluminium 6061, Quick-release 5 x 135mm, Disc brake Post Mount |
| FORK | SR Suntour, NEX E25-LO, Lockout, Steel spring, Travel= 63 mm, Steel steerer tube 1 1/8", Quick release 100mm |
| CHAIN GUIDE | Nylon directmount |
| CRANK ARM | Haibike, Forged, Aluminium |
| BRAKE (FRONT) | Tektro, T275, 180 mm, 2-piston disc brake |
| BRAKE (REAR) | Tektro, T275, 160 mm, 2-piston disc brake |
| TUBE | Presta valve |
| RIM | Ryde, Zac421, hollow rim, Aluminium |
| CLAMPING RING | Quick release, 34.9 mm |
| REAR DERAILLEUR | Shimano, Deore M6000 |
| SHIFT LEVER | Shimano, Deore M6000, Rapidfire, 10 speed |
| BOTTOM BRACKET | integrated in the motor |
| SPROCKET | Shimano, HG50, 11 - 42 teeth |
| CHAIN | KMC, e10S |
| CHAINRING | Steel, 38 teeth |
| BRAKE LEVER | Tektro, T275, Aluminium |
| TYRE | Schwalbe, Road Cruiser , 42-622, 28" x 1.60" |
| FRONT WHEEL HUB | Haibike Components, TheHub +, 6-bolt standard |
| REAR WHEEL HUB | Haibike Components, 6-bolt standard |
| SPOKES | Sapim, Leader, black |
| HANDLEBAR | Haibike Components, TheBar +, 720 mm |
| GRIPS | XLC, Comfort bo3 |
| STEM | Haibike Components, The Stem +, A-head |
| HEADSET | Feimin, A-Head Tapered, ball bearing |
| SADDLE | Haibike Components, TheSaddle |
| SEAT POST | Haibike Components, The Seatpost +, Patent, 31.6 mm, Aluminium |
| PEDALS | VP, E461, Aluminium, with Reflector |
| WEIGHT (KG) | 23.9 kg |
| PERMITTED TOTAL WEIGHT | 130.0 kg |
| HEADLIGHT | Trelock, Bike - i Veo LS230, 20 lm |
| REAR LIGHT | AXA, Blueline |
| CARRIER | system carrier, 25.0 kg |
| FENDERS | SKS, Chromoplastics |
| STAND | Ursus, Mooi, Rear stand |
