I am still thinking about adding reflective tape to my helmet.
Someone on another forum posted the following:
"With reflective tapes, the white is normally the brightest color. A tape that is "SOLAS" rated will have the highest quality and may hold up the longest.
If you only buy one color for your helmet I would suggest a white stripe all the way around. If you want to go up a notch, keep the white and run a second strip of red along the back and amber along the sides.
The tape comes in rolls and you can use the extra on your bike."
Maybe something like this. Although, this just happened to be one of the first things I found on Amazon. (SOLAS is Safety of Life at Sea.)
There are these Oralite 3/4" V82 (Type 5) Reflective Dots. A bit spendy, but they might work out on a helmet.
44 SOLAS 3/4" 1404 Oralite Dots M82
Oralite SOLAS Conformable Prismatic Diamond Dots. Easy peel and stick application. Makes diamond plate compliant with NFPA 1901 standards. Best quality dots on the market. Made by Orafol USA. Sheets of 44 - 3/4" dots. USCG Approved SOLAS is the brightest tape in the world. SOLAS stands for...
reflectivepro.com
