Rear Wheel Removal Tip
No it does not make sense :(
I do not like deceptive practices
26" X 4" doesn't make any damn sense either.
26" measures half way up the sidewall on either side of the beads across the diameter of the tire.
I've got three different sized wheels.
26" X 4" fat bike wheels, 27.5" X 2.8" semi-fat wheels, and a 29" X 2" front wheel.
All three wheels with the tires installed are the same overall diameter +/- less than ¼"
It wasn't hidden 🙃 ... but it's also not a pavement tread in any way.
Jumbo Jim"
THE FAT BIKE TIRE. Extremely light. The large volume can be ridden with extremely low air pressure. Ideal on soft ground, rough and very loose terrain. Available in widths of 100, 110 or 120 millimetres.
I rode this afternoon and had to go on and off the paved walk/bike trails to get around people walking in a group. I felt much safer with my knobby’s. There were spots on the paved walkway that had wet leaves from previous rains Monday night and Tuesday morning and there was still excellent traction If I ever decide to get new tires what do you think the Schwalbe Jungle Jims would do for me. I mean the tires that came on this aren’t that bad, just a little noisy on pavement. I am feeling safety trumps sound at the moment,
Ok Gionnirocket, mulling over everything I decided to buy the Kenda Cursor tires. They were on sale (couldn’t pass that up) and I like the tread and reviews.
I will either have to use the tubes I have now or find other as Kenda was out on them. Well one of three things will occur, A. They will work well. B. I might get hurt. C. You might never see me again. Let’s hope and pray it is A.
I don't know... C sounds pretty good 🙃 🤣
You have to understand that On and Off road requires a much different tread, especially if you ride spirited. There are hybrid all terrain tires out there, but not so much in the fat tire world right now. Even then they are a compromise as they don't excel as a single terrain tire does for its particular purpose.
You said that you ride mostly paved so that was the reason for my suggestion. I ride similarly and have swapped out for a more pavement oriented tread with great success on more than one occasion.... so have many others here. Sometimes I'm moving at 20mph and divert to off road to avoid a traffic jam without issue. When I had an off road tire I often found myself sliding on pavement, especially with aggressive braking and tight turns at speed. Not an issue anymore.
I'm sure the 4" factor plays a roll in your case, that's a lot of rubber on the road to begin with.
So though noise is a consideration... Traction, rolling resistance and even micro_vibrarions played a much bigger role in my decision.
As with any new/different tire... Feel it out and learn it's breaking point and you'll be fine.
Too bad they didn't have the tubes... That would have put you over $100 and gotten you free shipping.
So basically the tubes would have been free.
Why do people always want C. For me especially my wife LOL 😂
Yeah, I will try to find some puncture resistant tubes that are quality. If you have any suggests let me know please.
I'm not using thick or puncture resistant tubes myself.... But I am using Flat Out which seems to be working well as I haven't had a flat in over 8000mi.
The one flat I did get over 2 years ago was from a pretty big rusty nail.
I don’t usually go with just 2 reviews but the price is right and the fact that I will be using Flat out….who cares, right?
  • **Exact Fit 26×4.0 Fat Tire**: Replacement inner tube for 26-inch x 3.9-4.1" fat bikes, electric bicycles, beach cruisers, snow bikes; perfect OEM upgrade for Hitway, Ecotric, Ancheer, Samebike
  • **Heavy-Duty Butyl Rubber**: 1.1 mm thick wall, 30% higher puncture resistance than standard tubes, holds 30 PSI max, supports 750 W-1000 W e-bike torque on rough mountain, sand or city roads
  • **Schrader Valve & Rapid Inflation**: Standard 32 mm AV/auto valve, removable core compatible with floor, hand or CO₂ pump; sealant-ready for extra leak protection, keeps pressure up to 30 days
  • **Value 2-Pack with Tire Levers**: Order includes 2 tubes + 2 fiber-reinforced levers; vacuum foil bag prevents ozone cracks, easy 10-min roadside repair, ideal spare for long commute or bikepacking
  • **Anti-aging**: Excellent materials and performance Made of high-quality butyl rubber, it has excellent air tightness and aging resistance, as well as excellent puncture resistance and durability
I got the tubes yesterday and the Kenda Cursor Tires came today in one large box (Not folded like the last one). I have them outside the box in an unused bedroom to stay warm. In addition I put the Air shock on the bike and rode it. So far so good. I checked the air pressure and still holding. I love the new Silca High Pressure pump. Works really well and I really like the air pressure release. It lets pressure out in short measured releases for more precise way of setting pressure.
I just changed a rear tire on a RAD with a dual kickstand. What was nice is that I could put my folding stool behind it and drop the wheel because the kickstand lifts the rear of the bike by three inches. Then I used my toes as levers to lift the wheel back in place. I checked, this battery is not one of the bad ones. Next it gets a wash and a full tuneup.
This is what an electric bike looks like. Check the wire management. See the climbing gears. The display is On to the left. Although subtle in looks, It kicks the butt of $9,000 in-store bikes. The very best ones pass a regular analog bikes.
PedalUma, nice bike. Question does it have a motor and if so where is the battery?
Just take your time and be patient and don't try to muscle the tire on from the get_go.
Lube the bead with soapy water and having a little air in the tube usually helps. Work one side at a time.
An air shock is usually a noticeable improvement over a lower end coil. The micro bleed valve on the pumps do make it easier to dial in an exact pressure and are found on any decent pump.
The display is on the left - glowing blue. The battery is in the water bottle cage. And the motor is between the pedals. The battery discharge wire is inside the top tube and exits at the back of the seat tube and goes down to the motor in grey housing. The display wire goes up the down tube to the HB. Connections are soldered and sealed inside the motor. No slop or mess. Zero zip ties. No ugly wires.
I like the brown walled tires
This is what I am listening to right now while doing at tuneup and the replacing a motor core. I will need to chop the wires to the motor and solder in a new connector. It is easier to swap the core than to lace in a new motor.
