BEC111
I’m curious. After about 5500 miles, the derailleur of my Vado SL (Shimano Deore 10 speed) no longer shifts consistently. Sometimes it can’t shift to the smallest cog other times the largest. Sometimes it won’t upshift, others it won’t downshift. I spent quite a bit of time with the mechanic at my LBS (Conte’s Vienna VA) making all the usual adjustments to no avail.
The cassette is and chain are in good condition, clean and adequately lubricated. The mechanic believes that the main spring is the point of failure. It’s lost its springiness. Thus I’ll need a new one. We also discovered that the cap over the mechanism on the shifter had fallen off. That’s not urgent, but also not really replaceable, so a new shifter is probably needed.
Does 5500 miles seem a reasonable lifetime? Any other comments, welcome.
