Question about Voltbike Mariner
skytrack
Hello,
On voltbike mariner it seems throttle only works in PAS Level 1. When Bike is in PAS Level 0 throttle does not function. However on Yukon 750 throttle works fine in PAS Level 0.
Does anyone know why this is? Response from Voltbike rep was kind of confusing. They said it was due LCD Panel being different, but that did not make sense as LCD panels are the same on both bikes (at least they appear to me).
Also does mariner wheel diameter needs to be set to 22 instead of 20 in the controller firmware? It seems rep from Voltbike is suggesting that.
Thank you.
Yes on the 22 for fat tire to have speed and distance measured a little closer. Tire pressure can affect it also but 22 will be close enough. P10 was used in the past for throttle control (setting zero). Think they use the 800S display now that may not have that setting anymore. Maybe the facebook page would have better answers for you but wanted to say something here to help.
