DuncanC
- USA
- City
- Andover, New Hampshire
I am gradually gaining a firmer toe hold on programming the controller for my Bafang BBSHD 1000 Watt using a 48 Volt battery. My current understanding is that the Speed% is a setting for the chain ring rpm (motor rpm) after which assist basically stops. Apparently the maximum rotational speed is a function of the battery voltage and is 150 rpm for a 48 Volt battery. However does the maximum rotational speed decrease as the actual battery Voltage declines over a ride or does it remain at a fixed value? I suppose bench testing the motor with a strobe would easily clarify this. So having recently acquired a strobe I think I’ll drop the chain off and at least see if the maximum chain ring rpm is 150. If that works out I’ll check the chain ring rpm’s of the other 8 PAS Speed% levels and see what values I get. If it works out I’ll post the results. Too, I can check the maximum Speed% after a long enough ride to drop the voltage to a level that will allow a measurable rpm drop? I do understand that the controller may function in a more complicated and nonlinear way with the Speed%, but at least this will add some data that should not be affected by any subjective experience gained from a ride. Wish me luck.
Best regards to everyone and thank you all for your many thoughtfully detailed explanations and guides all based on extensive experience and understanding.
Duncan
Duncan
