Don't panic. That "4" probably wasn't your max in your highest assist level. I bet you were in a low assist level when you went into settings. On the current generation, there isn't just a "single global" current setting for amps. They changed how those work last year (LMT'D as well, as per LAmike's example in previous post.) See video below - I bookmarked it to that point in the video where it's mentioned. The current setting is PER assist level and will even vary depending on which assist range you are using. So you have to set your assist level, then go into advanced settings to make the change for that assist level. Then save/exit the settings, change your assist level to go back in to check the max current for another assist level. And on some of them, like my 700, it won't keep the setting for previously changed assist levels' current settings once you exit advanced settings, toggle the assist level by one and then back, and go back into advanced settings. If appears to save the change if you go back in without toggling the assist level. But if you toggle the assist level, then go back into advanced settings, it returns to the default. And that applies to at least some LMT'D bikes as well. Someone on FB first posted a video of his LMT'D display showing that behavior, and I confirmed the same on my 700. This is the video from his LMT'D:
https://photos.app.goo.gl/kwRCuJ6cfomifUzaA
But on my 700, it defaults to 16, 17, 18 AMPs in the highest assist level depending on the assist level range configured and was providing around 980 watts or so in PAS 9 set to 100% with about about 50 volts reading on the battery (it's much less on a low battery). I only tested that briefly a few times and typically ride at 0 W to 130 W using constant muscle power boosting assist up to 300 to 500 watts on the steepest hills. Other than testing, I haven't had a need to use maximum PAS. So, it's working fine with those default current settings that I can't change anyway.
Note -
Ride1Up has recommended not changing those percentages on the LMT'D because of how they have optimized them for the torque sensor. The 700 uses a cadence sensor. Someone on FB was having terrible performance with his LMT'D, maxing out at 35 W, but after some additional changes, he got it working well again. He didn't mention whether he reset his display, but if my display wasn't displaying my speed, I would try that after first trying to power cycle and even removing the battery temporarily.
www.facebook.com
Video bookmarked to the info on current (amps) setting being PER assist level:
Now
that's CONSTRUCTIVE ... and humbly welcomed.
The bike is now much faster. Not double, but noticeably/ nearly. Vey smooth now.
I set the assist to 0 - 3 (and I tried 0 - 5) still no speedo. Odometer is also stuck. Etc.
I pulled the battery, same same. What's the difference between 0 - 3 and 1 - 3 ? Hmmmmmmm ?
Settings available are from 0 - 3 to 1 - 9 (1 or 0 through 3, 5, 7 or 9. Eight combinations).
The (factory preset) Power set for "0 - 3" = 30%; 65%; 99% .
Reset Power Set to 0 - 5 =14, 23, 36, 50, 82% - and same problems, no change. Reset battery, etc. No change.
Because I left the % values unchanged, I can't speak to the reverting problem. The Power Set stayed the same as when I toggled out.
Note: I suspect some REAL differences (possibly in available settings too) between the software for cadence sensor and the torque types.
Also ... I keep saying this, and cause of confusion is mine - for using % instead of current - nevertheless: 30% of power = a specific, FIXED % of the total current powering 60nm; whereas that same 30% of the available total would underpower and limit the 100nm MXUS motor.
Am I incorrect ?
Okay. So, then if not is the %'s = 'the power being used from the battery to the motor' (current limitation), or the power the motor is developing regardless of current usage?
No matter. It comes out the same: A more powerful motor would be as strangled at the same fixed % of battery power use settings (limiting RPM) as one 1/3 less powerful, and would also be unable to use the current to develop the same RPM as the lesser motor, or develop any power beyond the limitations of the lesser motor's settings.
Thus, I can't see how one-size-fits all settings can even be close to optimal with such a "potential" power differences.
Empirical Statement time. FACT: Being equal and of relative scope 'Limiting the allocated current
limits all motors rated above that "limit" to that performance - or less ('less' because of larger windings and magnets, having larger power potential = increased resistance requiring more current / energy inefficiency, but more power).
I hope I'm making sense here. I'm assuming the percentages relate to the motor's power potential, not the batteries fixed % output, but either way it leads to the same result: An Ltd using the same settings as a 700 simply can't be correct.
The settings must be based upon the smoothest most efficient use of a specific motors torque curve/ battery usage algorithm software, not 'this works for another bike'.
Different levels "Sport; Athlete; Relaxed", (allocated percentages in our case) various parameter settings for that specific machine - just like an electric Car. One can't use the same fixed "sport" settings from a Prius on a Tesla S.
My Voltage is set for 48V, but it registers as 51V.
I set the magnets to 12 -- on scant info (sheesh. Come on R1U). It was set for 24. How many magnets in that MXUS ?
Speed Sensor's were at 4. I changed to to 12.
12 magnets, 12 sensors. Am I missing something? Should I use "virtual" magnets? What difference does it make?
I set my Current Limit to 20Amp. Tried 10Amps, seemed no different.
My two cents: I think current limit should be set to Motor's max usage (20Amps) / controllers potential (22Amps), whichever is less = 20 Amps.
I wondered if I should use the 11Amp nominal rating? But then I wouldn't even have access to the 22Amps my MXUS craves for those bursts, uphill, shifting gears, going full bore for a block or so. Yeah @ 10amps. right. for some other bike, perfect.
Bike is very fast[er], much smoother and the noise from the motor no longer that crunchy crackling grumble sound (I couldn't help visualizing a lightning storm shorting out in the casing).
Now it's more like a more uniform, humming, a bit crunchy buzz of high current. Maybe that previous sound was incorrect and presaged another problem? I only know my old Porsche used to sound like it was a disintegrating sewing machine and that was 100% correct.
I read I might have a loose magnet, but that was old, stale and based upon a Bafang motor problem.
My take: Most probable, the controller is dying.
Inappropriate to blame R1U. Sure. R1U
could use (NA or EU made) controllers that cost 15 x the price - and the installation would interfere with the supply/ delivery chain - so we'd be paying a monster premium. PLEASE DON'T.
Occasionally, I see a blip on the speedo display. If it says 1.2 mph, I'm running 25mph'ish (factor of 20 x
Any links or other info on speedo fail? Not critical but annoying.
It went up to "29.5mph" and everything froze. Previous "Max" information vanished. The display dimmed by 50%.
So, I > LCD setting = Perfect. So, I > Off. Restarted and display was full bright again, but some performance history information erased/ changed and no speedo, trip etc.
The display setting is at 31mph and the bike has often exceeded 31mph before any changes. Not sure if the history even showed it. Speedo did. Never broke 32mph that I'm aware of. Never checked.
Thank you for the insight. I've been looking at your posts and from the breadth of your knowledge I see why you're prominent in the community. I appreciate your taking your time.
Below is my baby, (1) full kit on bars; (2) rear fender on (after rain) and laser lit for the downtown evening; (3) stripped down for a recent winter day ride.
and (3) the view ahead.
Fn'F
