JES2020
- Other
Yeah , I'm pretty sure it's not a normally rated 1500w motor, even the KT manufacturer said that the cable config. on it, is for a motors 750w or less.I actually looked at that kit last year.
It is a really small-looking motor almost guaranteed to be overpowered looks more like a common 350-500watt motor.
If he is not listing the motor and he is not telling directly means he either does not know himself or you may not like the answer.
Anyway, that does not mean it is not a good motor. Look on the shell for any identifiers no matter how trivial they look, serial number prefixes are unique to manufactures.
Sometimes you just have to open them up and look for the manufacturer stamp the reason why is it may simply be rebranded or just lacking the original brand, nothing uncommon about it.
The motor looks a lot like a Bafang with the round spoke flanges.
If it has the lock spacers up against the inner race of the sealed bearings it is a good candidate for easy sealing, most likely it does.
And if you open it up and see tiny orange o-rings where the bearing slips over the axle that's even better as that means it is designed to have a waterproof rating, you may be able to add better larger ones just look on Amazon for metric sized silicon o-rings they sell kits cheap.
Most side plates have a large o-ring around them but don't count on it being oil tight
Thanks for the ID tips.
I have a couple things I'd like to open the motor for. Prepping for oil cooling is on the list. I'll wait for the winter down time to get into it.
In the mean time between riding it, I'm trying to learn as much about it as possible.
