I think the Espin manual says not to use a different charger.
Does anyone remember what size seatpost the Sport has? I ordered a new one and I want to order my Suntour XP seatpost in advance.
Do your new pedals spin more freely than the stock ones?@Taylor57 Did you ever change your pedals?
I installed the ones I got from Walmart, had to use the adapter but it added over an inch of outward length to them:
I think I have a slow leak on Sports back tire. Has anyone seen a how to video on repairing and adding Slime? I just happen to have an extra bottle layin around. Hopefully it's less drama that the XP rear tire...
Every time I take the Sport out (only occasionally because I mostly ride my non ebike), I'm amazed and how well it rides non-assisted. The gearing is pretty decent and the low friction wheels probably helps with the ride (the tires are more rounded than my MTB).
Then when I think hills are going to be an issue, the Sport takes them with ease. I haven't needed higher than PAS 2 to climb hills at a reasonable pace which is pretty surprising.
@Taylor57 Regarding the reach, I actually found the stem adjusts to almost a 90 degree angle. I didn't think it did originally but I was tightening things up and noticed that I could adjust it more now. Also, you can move your seat more forward on the rails to give you shorter reach to the handlebars.
Slime's video:
Seems straightforward... what was the drama on your XP?
I'm probably going to slime the Sport soon.
Nice. Thanks.
Every time I take the Sport out (only occasionally because I mostly ride my non ebike), I'm amazed at how well it rides non-assisted. The gearing is pretty decent and the low friction wheels probably helps with the ride (the tires are more rounded than my MTB).
Bnerd, what did it take to get your Sport back up and running? New front wheel?
