Riding Shoes; In Search of Something Better *Update!
Barefoot! A year ago I spent $30 on a pair of Whitun Barefoot shoes. No heel cushioning.... who needs it? I'll switch to industrial shoes if I might step on a nail sticking out of a board or drop a cement block on my toe, but the thin, tough rubber soles and leather-like canvas uppers are normally adequate. I was impressed enough that I bought a second pair 2 weeks later. I haven't opened that package because after a year of daily wear, I haven't even worn down the shallow tread on the heels of the first pair.
Such thin soles might be uncomfortable on some modern pedals. I use the flat kind.
That’s the pedals I use. Looks like standard issue Spesh. And really enjoying the shoe without heels.
You seem to be confused with different types of pedals. There are so called 'clipless' pedals and shoes using cleats. There are also cycling shoes for flat (platform) pedals, which are often equipped with traction pins. The sole of a cycling shoe needs to be stiff to efficiently transfer the power from the foot to the pedal.
The OP needs shoes for platform pedals. It takes the two to tango: the shoes and the pedals. I recommend Crankbrothers Stamp pedals, models from 1 to 3 (composite or metal), and these can be regular or Large.
The combination of Adidas Five Ten Freerider Pro with traction pin platform pedals is something I can recommend to anyone. There is nothing like "slippery" for such a combination.
Stefan, Due to a costly mishap I’m exploring going from SPD cleats and shoes to flat pedals/shoes. I looked into your 5 10 Freerider Pro recommendation and they look good but heavier and more bulky than I need. I only ride on the road so I’d like something light weight and don’t need aggressive lugs for trekking through the mud or hiking. I see 5 10 has a Trailcross LT that might be closer to what I’m looking for. Do you have any experience with that one? And your pedal photo - can those pins be adjusted inward further that you show or maybe if they make shorter ones? Im thinking for road riding in dry weather I only need little bumps for grip. Your thoughts are welcome!
None whatsoever :)
Someone else has to answer. No idea.
You see Calcoaster: When I was a noob in these Forums, one respected member (cannot remember who it was) recommended the combination of Crankbrothers Stamps and 510 Freerider Pro. I embraced that idea at the time and have never regretted that. Road, gravel or singletrack, a powerful or a lightweight e-bike: it has always been my choice. My feet are sensitive because of my ailment, and FiveTens protect my toes perfectly. Once, I incidentally dropped a heavy hammer on my bad foot but I had a FiveTen on it. No sensation. I felt no impact!
I went through Stamp 1, 3 and 7 and standardized on Stamp 3 Large. I tried Specialized 2FOs, and those were bad for my feet. Not sure if I can help you.
None whatsoever :)
Thanks for the input. I’ll read up on those three pedal choices.
Mine are BV brand. I don't know who made them, but they passed the Zedler Institute's tests for e-bike pedals. That sold me because I imagine it would be dangerous if a spindle snapped!
BV is in Illinois. They started as a dog-care products store. They claim they got into bicycle parts because dog owners like to pedal their pets around.
None whatsoever :)
Think I have a couple of those crankbrothers out there. What I found, is when the o.d. of the spindle the pedal rotates on is larger than the rest of the platform, the foot has a tendency to go to sleep, from that axle forward. Don't think I have any spiked pedals in use anymore, just went with the flat ones and never any issues, what I was using 50 yrs ago, good enough then, good enough now:)
The combination of a Stamp pedal and a Five Ten shoe holds as strongly as you have to raise your foot a little to disconnect the shoe from the pedal 😊
I purchased my first pair of 5.10 riding shoes in 2014.
Five Ten was its own company back then. They made their name, primarily, in climbing shoes. Then came other sporting pursuits. Note the materials list. These were leather, a little fabric and rubber sole. Awesome shoe! The upper was made outside the USA, the Stealth rubber sole was made in California and the shoe assembly was also done in California.
Sole:
I still have these shoes, and they can be worn, but after thousands of miles the contact area of the sole is worn flat. These shoes were so sticky and locked into the pedal studs like no other shoes I've ridden in. Note the size of the round lugs on the sole. They were crazy good and comfortable.
The next 2 pair of 5.10 shoes were after Adidas purchased the company. Soles and assembly were no longer in California and the sole material and style were dramatically changed. My first Adidas 5.10 had some leather trim, the next all man made. Now the soles are slippery, with a lot less grip and the latter due to the change in lugs.
Even in the photo of the newer sole, it reflects light, as though it is plastic and not rubber. The new soles are very slippery on hard surfaces and if the hard surfaces are wet...
I know there are fans of 5.10 here, as was I. Given my 11-year experience, the shoes aren't as good as they once were. I'm not saying the shoes are terrible. They could very well be the best MTB flats available, and while looking through Women Shoes for comparisons, I am on a search for something better.
Today I ordered a pair of:
Fox Racing Men's Fox Union Canvas Mountain Bike Shoe​
They have larger lugs as well. Better? Worse? I won't know until I ride them for a while. Has anyone had experience with them? Do you have any suggestions for me to look at?
I haven’t used the Fox Union Canvas shoes, but riders generally say they have good grip and are a solid upgrade over newer Five Tens.
I don't know the requirements of a skateboard shoe, so I typed it in at Amazon, and this was the second one in the top row.
Small world! I've worn the same pair daily for 17 months. Occasionally I've used super glue where the sole was coming loose. Otherwise, the wear is insignificant.
I'll share 3 different experiences. Upshot: Love my Five Tens, but maybe not a good idea on pedals without spikes or grit to hold them in place.
I went round and round with this years ago wearing stiff ass riding shoes and special pedals, neither did I ever like. Now I'm older and I just want to ride my bike, Skechers arch fit sneakers, and regular pedals work wonders.
1. Put 3,000 mi on my hybrid commuter in 2 years wearing Skechers arch support slip-ins on spiked MTB pedals. Yes, slip-ins, not even laced sneakers. Good grip with no sole damage. Great for walking off the bike.
Worked fine for the more casual recreational riding I was doing then. Wasn't just cruising, either. Always pedaled with exertion, usually at lowest assist. Lots of hills. Never once slipped off the pedals.
2. Ditto for Five Tens on my similar but considerably less expensive alloy MTB pedals from ROCKBROS. You can spend more on lighter pedals with better bearings, but pretty sure pedal traction would be about the same with Five Tens on most spiked MTB pedals.
The Five Tens are tolerable for walking off the bike. Do 0.5-1.2 mile dog walks in them now and then, but much less comfy than the more flexible Skechers.
My sportier Vado SL inspired a more performance-oriented road and gravel riding style. Between the stiff Five Ten soles and their rock-solid grip on the pedal spikes, this combo feels like an improvement in leg power transmission to the pedals over the same pedals with the Sketchers above.
A marginal gain at best, but I believe a real gain for sportier riding.
3. Recently rented a Gazelle with plastic commuter pedals with very low (worn?) traction nubs instead of spikes. My Five Tens slipped forward clean off those dry pedals during power strokes well over a dozen times in 32 mi.
I view this as a serious safety issue. Probably would have been better off with the softer-soled Sketchers on these pedals.
3. Recently rented a Gazelle with plastic commuter pedals with very low (worn?) traction nubs instead of spikes. My Five Tens slipped off those pedals in a forward direction well over a dozen times in 32 mi.
I once rented a Bosch E-Bike in County Donegal, Ireland to be able to admire the wonders of the Slieve League/Sliabh Liag. The only thing I was unhappy about were the stock pedals combined with my regular trainers... Especially as it rained from time to time.
I was provided with a helmet, a Hi-Vis jacket, handlebar bag and a pannier by the e-bike rental. I even got a map with five recommended trails (but had my Wahoo with me). The pedals were the weakest point!
I'd like to say a few words about winter cycling shoes.
My riding mate Marek has drawn my attention to the Scottish brand Endura. I bought a pair of shoes by name Endura MT500 Burner Flat Waterproof.
These shoes are very warm, waterproof and windtight. The "Flat" version is obviously for flat pedals (Endura also makes a "clipless" variation, which Marek wears for the cold season). In my opinion, these are the best winter cycling shoes I have ever owned. I wore them during the rain, in deep puddles, cold wind, and now these are the only ones I want to wear during the winter. It didn't happen my poor feet got cold during wearing Enduras yet, especially after I started wearing Endura winter socks :) The grip on the pedal is of course perfect.
I purchased Northwave MTB All Mountain Shoes Escape Evo Black/Green back in 2018 (Amazon, $90 back then). They last a long time for me because I only wear them when riding. They have stiff sole that doesn't flex to make pedaling easier compared to cross-trainer or jogging shoes I was using before. I like the Velcro strap for hiding the shoe laces. These had the option for clipless or clip pedals. They don't feel too hot during triple digit summers. I switch to my 3/4 top waterproof hiking boots when temps get below freezing.
