6zfshdb
- USA
- City
- Northeast Pennsylvania
That depends very much on how cold it gets and how long anything will be exposed to that cold. If you are talking only -5C or so than you probably have a little less to worry about. If you are talking -25C for extended periods than you probably ought to take some precautions.
Any lubricant or hydraulic fluid is going to have a minimum operating temperature below which it will no longer lubricate very well (or flow well enough to properly lubricate). At very low temperatures (and what "very low" means very much depends on the compounds in question) some lubricants and hydraulic fluids can separate, and additives (like teflon or graphite) can precipitate out of the oil. While in an automobile or heavy equipment usually there is quite a bit of volume that can act as a safety factor (although usually leaving your rig out in the bitter cold all winter without properly winterizing it means at least one shop visit in the spring) I suspect that the tiny hydraulic lines in bicycle hydraulic brakes and the tiny amounts of oil in wheel bearings or internally geared hubs won't react well if the lubricants or fluids separate.
Again, this is a "better safe than sorry" kind of situation. And given that I doubt many in the bicycle industry give much consideration to extremely cold conditions you are kind of on your own.
Good points.
It sometimes gets down to -10F around here but the temp inside the garage rarely drops below +10F. These readings generally don't last for more than a few early morning hours. I have no room in my heated garage for my three e-bikes but but an insulated & heated space could easily be built in the unheated garage. Might be worth doing.
Thanks for the advice.
