I attached audio of the old and new, quieter M620 rotor and third gear from Green Bike Kit. The first 3 seconds are the old gears, the last 3 seconds are the new gears. My old gears look practically new, so you're not hearing worn out gears.
Recording conditions were carefully controlled. Automatic Gain Control (AGC) was turned off. I climbed the same hill, in the same gear, at the same speed, with the same assist level. 20 MPH, drawing 1250 Watts at a cadence of 110 RPM up a 10% grade. The microphone was in the bottle holder on a Dengfu E22 frame, so you can hear wind noise from my leg going by.
Applying A-weighting, I measure a 3 dB decrease in sound level, which is 50% quieter. A-weighting is used to measure perceived sound levels, which happens to also greatly reduce the wind noise.
Not only are the new gears quieter, but I think the tone is more pleasant as well.
Edit: Installation of a new rotor requires calibration of the controller.
