voidedwarranty
Just read this. All new 7 speed Kindernay IGH based on their 14 speed model. Swappable shells available in 32 and 36 hole configuration and standard 6 bolt brake disc compatability. 428% gear range with evenly spaced 28% steps
More big news is the new trigger shifter mechanism. They have done away with the split twist shifting found on the 14 speed in favor of a traditional trigger style shifter. Still hydraulic with quick release. No price yet. Available fall 2021
Multiple sizes available in 10 and 12mm thru axles. Sadly no support for fat bike drop outs. Max drop out listed is 148mm I believe
*Edit*
There is a better discussion about this topic in the Parts and Accessories forum.
All-new Kindernay VII 7 Speed Internal Gear Hub gets 428% range & high torque capacity
The Kindernay VII is a wide-range 7 speed internal gear hub designed for high torque eBike applications with SWAP Cages for wheel changes
bikerumor.com
*Edit*
