It has been mentioned in a few threads here but Reention is producing a new case for their Dorado series of batteries that allow 21700 cells to be used instead of 18650. This increases the max capacity of that battery to 25ah using Samsung 50E cells (@48v). The battery is available in 36v, 48v.
I pre-ordered one for my NCM Moscow before the case was even available through Aijiu Energy and @Jenny Mao who is a user here on EBR. The battery arrived today and I made a couple short videos, I did an unboxing video and then I realized I should have had an existing Dorado handy for a size comparison so did a 2nd short video on it. These are the the first videos I've ever made so hopefully they are ok.
Unboxing:
Quick compare to existing Dorado:
I added a video showing the battery on a narrow frame step-thru bike:
(No idea why youtube links don't always work. Grrr. Search for "Dorado 21700 25ah" if needed)
So far the battery looks good, it fits the NCM Moscow I have now (it's taller than a normal Dorado). It arrived in perfect condition visually, I haven't ridden with it yet as it's charging (and it's raining out), but we have a 3 day trip planned with it so I'll post a real review after that! It's a big battery but the capacity is going to be great. The battery charge connector has moved from the bottom (down near the mud and water) to the top which is a smart choice I think. The water cover over the charge and USB ports is much thicker and heavier than the old covers (and has screws for easy replacement).
I ordered mine with the 2.1mm barrel connector for charging which limited me to the 3A charger but there is a 4A available using a 3-pin connector by Reention, 4A would really speed up charging for sure.
The battery has no rattles or loose parts, seems very well constructed. I've said before Aijiu and Jenny have been fabulous to deal with, I got a bit of special treatment since this was a pre-order for a new format of battery case, so I was able to see it's construction, the cells, the nickel strips, etc. It all gave me a great sense of confidence in Aijiu and so far so good![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
The packing was great, there was a slit in the foam around the battery and Jenny has said that must've been from customs inspecting the box (which did add a few days to shipping but with customs its a bit of luck to know if your package will be delayed or quick), that's no fault of Aijiu. The battery box arrived with all the proper lithium ion warning labels too.
Overall it's great so far. Just need to get some km on it now! Ask me any questions you have and check back for a full review later.
Here's the link I ordered from:
www.alibaba.com
Unboxing:
Reention Dorado 21700 48v 25ah Ebike Battery High Capacity Lithium Ion 48v 52v Ebike Battery For 1000w 48v 52v Ebike - Buy Dorado 48v 25ah Ebike Battery ebike Battery 48v Ebike Battery Product on Alibaba.com
