A tenergy 18650 batter spec sheet is here:
http://www.all-battery.com/productimages/li-ion/Data sheet 18650 2200mAh.pdf
So nominal voltage of 3.7, a 36 v battery would be 9.6 in series, so 10 in series. I don't know how you divide 45 cells into stacks of 10.
Normal discharge current of one cell would be 1.1 A, I believe they say, so 4 stacks would get you 4.4 A. 4.4 * 36 +158 watts. That is pretty light. You can rapid discharge at 2.2 A but you better not do that very often. That is 316 watt, more than many middrive motors. I searched global bicycle motor and got a lot of for sale links but none titled global brand.
My geared wheel drew 400 W up 15% grades at >10 mph and >700 W below 6 mph. that was at gross weight of about 220 lb. I had a 30 amp rated battery (48 v) of 11 stacks.
