PedalUma
- USA
- City
- Petaluma, CA
There is a little Philips screw facing out to the side. That is the spring tension adjustment. On the side that is not moving, screw it in all the way then start backing it out as you squeeze the brake lever. If this does not do it then you need to remove the five millimeter bold at the front of that side and grease the smooth shaft and brass washers.
