Fast n' Furious
- USA
- City
- San Diego
Yes. Risking 'racial appropriation' accusations, I've tried the 'dew rag', 'bro'.If a helmet were pulling my hair out I think I would try wearing a thin cloth head covering under it for prevention.
The added "Aunt Jemima" touch offset the 'Alien' theme, but drew stares at the long-haired, older (and sweaty) white guy in the goofy helmet - with the 'dew rag' (exacerbated the heat problem, subverting the airflow). I didn't look Like Giuliani w/ trails of runny-mascara down my cheek, but my brain was saying 'it's too hot in here, oldtimer', so I dumped the rag - homie.
It's my own fault. I was a sucker for the fabulous '2/3 off' price and the *&#@* Giro came in black. Great for the Swiss Alps.
It'll probably void the warranty, but I'm' a gonna' spray paint it in (drum roll) 'titanium' w/ grey metal flake.
I wish more experiences from those who opted for the Rohlof IGH were posted.
I can't test a bike and want to pull the trigger.
Against my overall plan, the Kindernay lacks a twist shifter. I really tried to accept the SA 3SP, but it's a serious compromise for my build. Endless research says it's the Rohloff.
Hey laid up Guys, or anybody rockin' a Rohloff. Tell me your experiences?
A couple things I note. The reason WW UC & CT bikes lack handlebar 'real estate' is the thumb throttle shifter(s) are hogging it.
Excess wiring? I use two detachable, rechargeable (front) lights that run 400 lumens for >11hrs each on low (18650 3500mw).
One is more than ample - cars high beam me if I adjust incorrectly. No wires; removable to prevent theft/ use as a flashlight; the mounts take up .75" each on the bars. My GoPro mount takes up another .75" and on either side of the head-clamp my basket's quick release mounts, about the same.
As an old photo shows, one light, on low is plenty. Upgrading to two, next to last photo shows the present, 2 'slide-on mounts' on the extender bars (lights detached & stashed in downtube bag), the center mount for the basket and the GoPro mount.
An extender is needed because the +$%#@* display interferes with everything for 4" on one side and won't mount on the other.
As can be seen, center mounting the display = problem solved - not cluttering the middle of the bars. I'm hoping the WW's display is mounted to the top cap (like w/ the last photo's device), where it belongs.
For taillights, I like my Meilan Laser, wireless lighting . Look Ma, (more) NO WIRES !!! Not sure why, but every light I've had on the butt end of my rack ends up broken or just disappears.
The pic's under City lights, I don't use the side laser or even 'nightcrawl' much, but when I do it works perfect every time.
They're ($37) on Amazon so I ordered a new one yesterday - for a spare.
Solid Bluetooth. Great attachment system. Removable in a flash. Mounts to seat or post, press clip, slides off. Use every night, holds a charge for 4 - 5 days. You need more? Buy two. They weigh nothing and can be stowed easily for extended night-crawling.
The Meilan was the only one I tested with a controller/indicator that was decipherable regarding what was going on back there.
The others, you'd get off bike and here's this pinwheel lightshow flashing. Turn on a turn signal, it wouldn't turn off, unless you turned the other on, which then wouldn't turn off either.
Great weather and great rides today for me.
Good energy and thoughts to those recuperating.
Fn'F
d6b29907-4865-47eb-8828-04257976cafa.__CR0,0,300,300_PT0_SX300_V1___.jpg35.7 KB · Views: 355 -
