Any experience or known threads focused on tubeless Tannus? https://tannusamerica.com/pages/tannus-armour-tubelessCorrect you want a tube
I don't know.What size dropouts are you running with the front fork? 100, 110, 135, 150?
I decided to go with the 26x4 fats, to maximize cushion (my back is a mess). Your comment about 27.5 x 3 makes me curious, given that's close to how my non-ebike is setup.Also if your going with two sets of tires ( 29" & 26") won't you need wider rear triangle for the 26 x 4.8" set-up?
The AMA @pushkar provided frankly scared me away from unrestricted. I thought with 2300w I could still get more juice than 1/1.5, I just don't run the risk of breaking things with throttle. I want the max juice available given I have so many steep hills to climb around here. I'm an ebike newb, so I will read up further on this point.Why would you want a restricted throttle with a 2300w controller? Whats the point of the extra wattage. Or just get the 1000w or 1500w version with the derestricted throttle option it's cheaper.
I'm super curious about this, I'll read up more, my current bike (not electric) is 27.5 x 3.8 and I enjoy how those take on any terrain. I'm wondering if the 26 x 4 would disappoint.One last last point is tires for a cushier ride. I use to run 26" x 4" fat tires on my older bikes and thought that was the only way to go until I tried out some 27.5" x 3" tires and now I would never go back.
Thank you! Haha, I guess the lead times allow me some flexibility in having these type discussions after I thought I had the spec dialed in. @pushkar has been very nice in allowing me to tweak a few things in the spec as purchased before the build begins.Good luck on your new ride hopefully it won't be 2022 when it arrives. You guys have the patience of a saint!
They might. In my opinion, 27.5X3.8/4.0 tires are better than 26X4 in pretty much every way--faster rolling, better rollover, better handling (more like a plus bike, less like a "fat bike") making the bike a lot more fun to ride in the summer...and they're still better in the snow. Personally I'd only go for 26X4" tires on a bike only if it wouldn't fit 27.5's.I'm super curious about this, I'll read up more, my current bike (not electric) is 27.5 x 3.8 and I enjoy how those take on any terrain. I'm wondering if the 26 x 4 would disappoint.
I'm currently on a Farley EX, Bontrager Hodag, Tubeless Ready, Inner Strength sidewalls, aramid bead, 27.5x3.80˝27.5" x 3.8/4.0 tires?? The largest tires for 27.5" wheels are 3" unless you want the winter steel studs type. Not trying to nitpick just want to clarify.
Dag nabit Robertson you make my teeth hurt! How can any one man know all this s*it? What are your consultant fees? Like by the minute. Can I just call you up and get answers cause I can barely follow half this stuff. Really. I'm not kidding.The only real functional difference between an MT5e and MT7e is the brake pads (which are a nice step up in torque). I know Magura wants ransom for them, but I have always bought MT5e's, then ran the Type 9 pads (MT5 2-pc) down and replaced with Type 8.P (MT7 pads). The calipers are the same minus the shiny finish and the plastic ring inserts. The MDR-P rotors don't impress me much either. I used an MDR-C on a recent build and it had a little more mass, but the same thickness as the old school Storm HC, but my favorite remains the thicker Tektro TR-17 which you can inexpensively add later. A basic Magura rotor is going to be a good fit without an upgrade.
I would say though, that the Ergon Prime Core is worth the extra money. I have three of them on different bikes. Also have an Ergon SMC on another bike and its an excellent saddle, but the Prime will stay comfortable for longer rides.
It's not an option for the Hydra, but that sounds cool, I would if I could.Can you run 29x3.0 ??
You could probably run 29X3.0 up front and 27.5X3.0 in the rear with the right front suspension fork. Don’t think there is clearance for a 29X3.0 in the rear.Can you run 29x3.0 ??
Yeah, many fat tires perform quite well in summer conditions--often offering significantly more traction than normal sized MTB tires on most terrain--and I've found the 27.5X3.8/4.0's have fewer downsides. Maxxis actually makes the FBF/FBR in that size which are quite popular.Learn something new everyday thats what I get riding Maxxis.
The cushy ride is probably the biggest reason I ride my fatbike more often than my 29er trail bike, even in the summer. One can spend a fortune on the latest/greatest shock and fork, and still never get the small bump compliance/trail chatter smoothness of what being able to run tires at 1/2 the pressure offers. And there's no doubt the better rollover and traction makes difficult climbs much easier.I'm editing my initial post to show how the build is updated. At this point, I'm thinking I should go with 27.5 and 29 wheelsets. I don't need to make it through fresh snow or deep mud, rollover-ease and cushy ride are my primary goals.
I'll just run with what comes standard - I'll give the 27.5 x 3's a whirl. Hopefully the .8 doesn't change the cushy-ness too much. I'm hoping the Tannus makes up in cush.Looking at your build, if you do want to run 3.8's I would guess you need the 197 rear triangle and probably the Mastodon on the front.
