Merle Nelson
- USA
This is one thread I had not seen. Thanks For posting on it.
6213 miles is years for me.There was article about an advanced rider that had to change his belt and sprockets every 10K KM, that is a huge amount of Ebike riding.
There are tensioners available https://www.santosbikes.com/en/santos/santos-only/santos-belt-tensioner1) There are no off the shelves tensioner you can buy that I could ever find, each manufacturer makes their own for their own bike.
If you figure out your bike could use one from a brand bike, you may be able to buy it as a spare part.
BUT tensioners are intricately linked to the bike geometry and the sprockets used, as how much slack they need to take while maintaining belt tension is a function of the Chain stay variation, and what belt length can be fitted on a given set of front and rear sprocket.
Gates only manufactures certain belt sizes (tooth #), so depending on your chain stay and the sprocket used, you may have to install a belt that already has some slack even at the longest chain path. A given tensioner can only take so much slack, and if that is not enough for your specific bike Geometry / Belt length, it wont do the job.
2) The Hydra does have the ability to open the rear triangle as you can see on the double bolts at the back.
10,000 Km is less than 1.5 years using my averageThere was article about an advanced rider that had to change his belt and sprockets every 10K KM, that is a huge amount of Ebike riding.
That is higher than normal, if it would last 5 years for me, I would would be happy with that.10,000 Km is less than 1.5 years using my average
I'm replacing mine after 3000 miles. Some teeth on the belt failed, causing slippage.That is higher than normal, if it would last 5 years for me, I would would be happy with that.
Reisse and Muller have one that has been out for awhile I haven't heard any complaints from their forums here on EBR on that aspect of the Ebike.
May be a problem tensioner's can't cope with Ultra's 147.50 ft-lbs of torque. Gates Carbon Belt was designed for bicycles (human , 20nm max).An Arm and a Wheel does not make a suitable tensioner for any bike.
I actually just finished a full analysis on a tensioner for a Full suspension bike, and there are way too many details to goo into.
As I said before for bikes with small travel, or chain stay that don't vary much, making a tensioner work can be fairly easy if the geometry can accommodate the tensioner travel, even out of standard pieces like you referred too.
Once you get into Large rear travel bikes like a mountain bike and/or geometry that creates big variation in the chain stay, the problem becomes exponentially more complicated as a single wheel tensioner may never have enough travel or room within the swing arm and frame to take all the slack or maintain proper tension throughout.
Now every problem has a solution, how complicated/expensive that solution ends up being ultimately drive if it is worth it![]()
I'd like to know more. How did it happen. What were the conditions it failed under? Your Wattage? Rear hub type? FS bike?I'm replacing mine after 3000 miles. Some teeth on the belt failed, causing slippage.
The problem is not the torque, Gates belt can take way more torque than that.May be a problem tensioner's can't cope with Ultra's 147.50 ft-lbs of torque. Gates Carbon Belt was designed for bicycles (human , 20nm max).
I see your point on the 'travel changing geometry' issue.
Wattwagons Cross Tour (hardtail), 2300 Watts, Rohloff rear hub. I was biking quite fast, around 30 mph, in ECO power level 5, when a vehicle pulled out in front of me and I braked very hard and slowed considerably to around 10 - 15 mph. When I began to pedal again at this slower speed, I forgot to lower the power level as I normally would do and a few of the teeth on the gates belt suddenly failed (partially tore off). I can take pictures of the failed belt and post them if that would be helpful.May be a problem tensioner's can't cope with Ultra's 147.50 ft-lbs of torque. Gates Carbon Belt was designed for bicycles (human , 20nm max).
I'm thankful you commented and wouldn't think of doubting your veracity. Posting photos would be helpful for many.Wattwagons Cross Tour (hardtail), 2300 Watts, Rohloff rear hub. I was biking quite fast, around 30 mph, in ECO power level 5, when a vehicle pulled out in front of me and I braked very hard and slowed considerably to around 10 - 15 mph. When I began to pedal again at this slower speed, I forgot to lower the power level as I normally would do and a few of the teeth on the gates belt suddenly failed (partially tore off). I can take pictures of the failed belt and post them if that would be helpful.
Yes, sintered, honeycombed Ti interior skeleton, with a bonded exoskeleton of resin impregnated Kevlar.Does it have to be titanium ?
Interesting.There was article about an advanced rider that had to change his belt and sprockets every 10K KM, that is a huge amount of Ebike riding.
Deacon, it's not my place to say obviously, and I don't know for a fact, but I have suspected WW was about ready to bring out something on this order and more. More able to handle torque than the gates, more retrofitable.While watching a Youtube video on belt drives for bicycles the presenter mentioned that there was a company that made a spiced belt. With this belt you don't need a bike with a split frame to install or take off the belt. Very interesting.
Belt Drivetrain Components For Bicycles | OEM & Dealer
Offering belt drivetrain solutions for E-bike applications for OEMs and Dealers internationally! Innovating the first splittable belt that doesn't require a split in your frame. We also offer traditional, looped belts for high powered motors. Our talented group of engineers will develop your...www.veercycle.com
The problem with split belt is that they definitely cannot take the 2300W of an ultra with X1. And yes it has been triedWhile watching a Youtube video on belt drives for bicycles the presenter mentioned that there was a company that made a spiced belt. With this belt you don't need a bike with a split frame to install or take off the belt. Very interesting.
