Gee_Whiz
Frey HT1000 Bafang Ultra Electric Ebike 1500W Mid-Drive 48V 21AH Large; located in Washington, DC - $3500
Used Glossy Black Frey HT1000 28+MPH e-bike; features integrated/removable battery, charger, throttle (no speed cutoff) etc 27.5x 2.2 wheels (kenda qwik)
Size Large
Delivered from Frey May 2021
No mechanic issues, no physical issues (however there may light scratches, dirt and other signs of use from road debris, trees etc..)
Bike is HEAVY - 65 lbs
Bike is very fast. Currently tops out around 37mph. Please be mindful of this. Speed limiter can be set in the settings. Currently set to unrestricted.
Bafang motor can be reprogrammed to suit many styles of riding. Programming cable included.
Bike is under Warranty until May 2023 for the electrical system: battery, charger, motor system and bike framework.
Bike range in PAS 3-5 is around 30-35 miles.
Specs:
Motor: Bafang Ultra G510.1000 48V 1000W mid-drive motor system.
Battery: 48V/21Ah with 78pcs Samsung3500mA cell
Front fork: ROCKSHOX RECON 150mm air suspension front fork;
Handlebar & Stem: Haibike Xduro Mountain Bike Handlebar - 31.8mm Clamp - 680mm W 15mm Rise
Seat post: Promax brand alloy.
Saddle: SR sport comfortable saddle;
Brakes: TEKTRO HD E725 4-piston Hydraulic disc brakes
Transmission: SRAM NX 11 speed gears, 46t Wolftooth Chainring
Tire: Kenda Kwick Drumlin 27.5 x 2.2 flat tires
Pedal: Crank Brothers Stamp Black
Color: Glossy Black
Ergonomic grips
Option parts: rear rack
F/R automatic lights
Programming cable
Tuning motor:
electricbikereview.com
If interested locally, please note:
A short phone call will need to be held prior to meeting.
Full cost of the bike will need to be held by seller for test rides and a valid license. No exceptions due to the cost of the bike, weight and speed. Also, please bring your own helmet if possible. Can also test ride in building loading dock or garage area with just license.
Adhere to social distancing protocols. Mask etc.
Size Large
Specs:
Color: Glossy Black
Ergonomic grips
Programming cable
![www.frey.bike](https://intl-image.yzcdn.cn/images/2023/11/01/57a8d1ad142863ed9eddd0cb60320541.jpg)
Best Value off road Electric Mountain Bike | Frey Ebike
Frey electric bikes are known for superior performance and reliable quality, and for long range ebike and big power ebike. It is a famous brand & manufacturer of the best off road electric bike for adults. We produce affordable electric bikes and accept OEM. USA/Europe warehouses for fast delivery.
www.frey.bike
Tuning motor:
![electricbikereview.com](https://partner-dashboard.electricbikereview.com/logos/ebr-logo-white-lg.png)
Bafang Ultra "Smooth" tune by Mike at Frey
So recently I decided to scrap all of my original ideas, which all seemed to dead end, and try something completely new. I went back to all of the original settings, and when I test drove that, it reminded me how bad those setting really are. No point detailing, if you're reading this you likely...
![electricbikereview.com](https://electricbikereview.com/static/assets/images/ebr-favicon.png)
