marcparnes
If you're looking to keep track of your tire pressure and get alerts in the case of a leak, slow or fast, this product does a superb job. I've been using it on my motorcycle for a few years now where its saved my butt more than once. I recently traded the motorcycle in for a new one equipped with a built in TPM so I moved the sensors over to my R&M Superdelite. The 7.6 gram sensors are very small units that screw on to your Schrader valve. I don't think they have them for Presta valves. The sensors are battery powered and the replaceable battery seems to last about 1 year. There is an app you download to an Apple or Android phone which monitors pressure 24/7 in both tires and alerts you if the pressure drops below a predetermined level or if the pressure starts to drop quickly as in a flat. It also displays tire temperature and compensates the pressure readings for current temperature and altitude. It communicates via Bluetooth so you can check your tire pressure even sitting in the house with the bike in the garage I've emailed the company a couple of times with questions and they've been very responsive, usually within 12 hrs.
Here is a link to their website where you can get more detailed information or place an order. FOBO Bike 2 is also available on Amazon (what isn't?).
Marc
Marc
