I believe you will find that both the 10.4 and 13.6 are both the same physical size. So both will have the same "sleek look." If you've done much FLX reading you will see a regular theme of folks wishing for "more range." You might keep that in mind in making your decision - you will likely find that the "range" is not as advertised.
