Joergen8
I've been trying to source spare matching rims for my Evo 29er, in case I needed them in the future, and was also planning to build another wheelset with a wider rim than the original 18c internal diameter, including buying a complete new rear wheel with motor (which turned out to be more difficult than it should be, and I wasn't able to buy one at all).
I don't know if BH has any support plan for their bikes what comes to their OEM rims (Alex Rims) through their dealer shops, ie what happens if your OEM rim needs to be replaced, do you end up with mismatching wheels sourced from the open market, or does BH supply matching OEM rims to dealers. But from what I've found, the Alex DM18 in anodized black and 622/700c, 36h is surprisingly hard to come by, but the same size in CSW (machined) sidewalls is widely available. I could try painting the sidewalls, but paint doesn't stick too well to aluminium, which is why the originals are anodized, not painted.
The bespoke spokes on a hub-motor are not easy to come by, so if your spokes are still in good order, you could just get another rim with the same Effective Rim Diameter (ERD) for both wheels.
For a wider rim, I looked at the DM24 from Alex Rims, which is available in all black from the good folks at Grin Technologies, but it has a slightly shorter ERD than the DM18. The original DM18 ERD is 607, and the DM24 is 605, which makes the original spokes on the hub-motor wheel 1mm too long. I asked a couple wheel builders and they said this could be a problem as the threads on the spokes might not be deep enough to tighten. Though the experts at Grin suggested the 1mm might not be an issue. I guess I'll have to find out.
http://www.ebikes.ca
Also, the Shimano M758 15mm thru axle hub in 36h, that came with the original front wheel on my 29er, is no longer manufactured and is hard to come by. There are alternatives, like the Hope Pro 2 Evo, but not many. I was still able to source the Shimano hub, as I'd like both front hubs to be the same and/or have a replacement at hand should I need it.
edit: Just received word from Alex Rims European office, that the DM24 in 622 is not available in Europe for aftermarket / end consumer. Which is too bad, since it's available in all other sizes.
