Epik Carbon
jnyoak
I'm interested in the Epik Swan that has been reviewed and also the Carbon. I'm curious if any of you have had any experience with it. Thanks!
Motor: MXUS 500W Rated with 750W Peak Rear Brushless Geared Hub Motor
Battery: 48V 11Ah Samsung 18650-Cells Lithium-Ion
Range: up to 40 miles (depending on terrains and rider’s weight)
Recharging Time: about 4 hours (at the low battery)
LCD Display: ON/OFF Power, Speedometer, Tripmeter, Battery Indicator, Pedal Assist Level
Pedal Assist System: 5 Level Pedal Assist, Thumb Throttle Control
Frame: Aluminum Alloy Folding Frame With Modern Design
Tires: 20” x 2.25” Kenda Puncture-Resistant Tire
Seat: Velo Seat With Pressure Reduction and Enhanced Shock Absorption
Brakes: Front/Rear: TEKTRO 180 mm Rotor Disc Brakes
Gearing: 7-speed Shimano Tourney
Accessories: Front & Rear Reflectors
Weight (with battery): 55 lbs.
Load Capacity: 300 lbs.
Dimensions: L65″ x H45″ x W24″
Dimensions (when folded): L38″ x H29″ x W20″
Colors: Black Matte, Tangerine
