For those of you even remotely interested in this etrike;
I have no interest in owning an e-trike and you may very well have purchased the Best E-Trike that money can buy.
I do know that the MeetOne Tour would be the trike I'd want if I did want one.
However,.. I'm with
@sc00ter and I'm really curious to know how this trike works for you.
I know that if it were mine, I'd load it up with the recommended 500 pound payload, two fully charged charged batteries, unlock it to 37.9 kph and hammer the throttle to set up a baseline for the Absolute Worst range possible.
That's something that I personally would want to know about any electric vehicle I would ever own.
s*it always happens, and when it does, it's gonna happen at the worst possible time.
And we all know that bad luck comes in three's.
I was out for one of my 85-100 km rides when I encountered this,..
I had no idea that the Bridge was washed out, and had to do 9 km detour.
That's not very far, but it is on an ebike and it would have Sucked to run out of battery and have to pedal unassisted for even 2 km.
When I finally figured out how to attach a second battery to my ebike, I took it for a range test where I could FINALLY Run my 25ah battery all the way down to see how far I can get on a Complete charge.
I was getting a little tired after a couple hours and decided to hit the gas and just kill the battery (my controller cuts out before the battery's BMS shuts it down at ~40V)
I made it 72 km (full throttle at the end) before my ebike finally shut down.
I went to swap the battery and realized that I forgot the Damn key for the battery lock on the e-bike !!
Luckily, I was only 7½ km from home, and it was the voltage sag from full throttle that shut me down, so I had a little bit of juice left in the battery.
So I worked the throttle gingerly, and helped by pedaling. I could get some distance before it shut down on me again.
The battery finally shut down for the last time when I had about 2 km left, and had to pedal the rest of the way home.
That did kinda suck, but it could have been worse.
If I had been further out, I would have used my multi-tool and a rock to smash the battery bracket to release the battery.
You always need a backup plan.
I ended up shaving the key down to a nub, and gluing it into the keyhole,..
I can still remove the key and use the second full size key if need be, but I don't need to lock the battery or the e-bike.
I'm always with my e-bike unless I fall off, but I always land close by.
