biknut
The reason I'd advise against the Grace is, first off, it's mid drive. Main advantage to a mid drive is hill climbing ability, but you don't need that. It's true a mid drive centralizes the weight, but you're not doing to be going fast enough to matter. A big disadvantage of a mid drive compared to a hub motor is maintenance. Since a mid drive uses the chain and pedal gears for drive you can expect a lot higher wear on all the drive components compared to hub drive. Another disadvantage, and this is a biggie if you plan to ride on city trails, is mid drives are noisy compared to the near silence of hub drives. The reason that matters is because there's a lot of haters on city trails, and they don't like eBikes, but the silent ones are hard to tell the difference from a regular bicycle.
Sure they can. You can put any seat you want on one, but keep in mind, seat posts come in 2 or 3 different diameters.
I don't know what diameter Stromer's have, but someone will probably know.
@EMG do you know if the Stromer can accept standard seat posts? I'm thinking of getting a pneumatic shock absorber for the seat...considering a thud buster... it would make my ride feel a lot softer.
