Freshblood
Hi,
I have a question about continous amps output. For example, some batteries output about 5amps continous and with 6 in parallel it makes sense it has a 30A continous BMS. What if the batteries had 20A continous with 6 in parallel. This would be 120A continous. Could I use a 30A BMS or MUST the BMS match the 'potential' continous amperage of 120A? My motor is a 1000W and battery pack is 37V. The motor can never draw more than a 1000W so it will never draw more than 1000/37 = 27amps? Right? This means a 30A BMS would be sufficient?
What is the pros and cons here?
