I'd like to try my longest ride ever on Thursday. 44 miles (flat). I have a 2016 Turbo X (250W motor) with an upgraded 691 Wh battery.
Say I want to use no more than 90% of the battery and it starts at 96%. That means I can use 86% of 691 Wh = 594 Wh. Over 44 miles, that averages out to about 13.5 Wh / mile. Since each 1% of my battery is 6.91 Wh, I should know if I'm on track if I see 2% of the battery go down for every mile that I ride (2%/mi * 44 mi = 88% used). If I'm using more than that, I have a bailout option but I need to know in time. First off, does my math look right? Am I missing anything?
I was just planning to go for it using the Eco30 setting and trying to keep my cadence high and my speeds a little slower than the usual full blitz.
Should I instead be using Mission Control to control the motor's output to make sure I get there? Has anyone used MC for something like this and does it work? I would rather not experiment with it for the first time in this situation unless you guys are confident that it can actually do this.
Thanks in advance!
Thanks in advance!
