PCeBiker
No-Hands No-Pedaling No-Credentials
- Canada
If your battery is a 48V 25Ah with these cells it is probably a 13S 5P configuration
5 cells in parallel provide 5 x 4.9Ah = 24.5Ah
These in series 13 times create 13 x 3.6V = 46.8 Volts (manufacturer often use 3.7V for their calculations... hence the 48V)
If so, then its max safe charge current would be 2.45 A x 5 = 12.25 Amps
With possibly a peak charge for brief moments of 4.9 x 5 = 24.5 Amp
So with being said, your 8000 Watt e-bike should be able to safely produce roughly 4000 Watts of regenerative power?
The specs do say though "(not for cycle life)" and the standard charge rate is half the maximum.
My battery came with a 4 amp charger but I only charge it at 2 amps to help increase my cycle life.
I don't mind waiting for it to charge.
