Umm.. I don't quite understand the point you are trying to make.
You can set the BMS to limit charging to % of the SOC. Greatly simplifying it but the BMS "voltmeter" component essentially needs to know what series pack it is (14S / 13S etc) and then % SOC will work off of that. Check out
This is pretty sophisticated - and you can actually cut out charging over a certain amps as well - very very similar to the satiator. Cant create "profiles" but definitely a big step up from whatever most users have today. This is not a new idea, and doesnt equal to "entire charger is on the bike".
1. Most / All ebike batteries need DC current.
2. All ebike chargers convert AC to DC (for the most part)
3. Tesla chargers are DC chargers IIRC
4. Regardless of what charger you have, the SOC needs to be defined somewhere. If it is not defined, it is assumed to be 100%
I have a Satiator charger too - and it is a GREAT charger. However just because it can do something doesnt mean it will be used like that.
I dont know about you, but all my battery packs are 52V, and except for probably 2 times over the last 4 years or so, I have never had to program anything on it. It is great, no doubt, but for an average user the benefits of "programmable" part are minimal at best. Heck, I would go so far as to say most people with satiators have not even downloaded the program, or connected to the charger at all. You know why ? because it needs a separate programing cable that doesnt come standard with the charger.
I am not trying to underplay the importance of a good charger like the Satiator. WW is trying to cater to the 95% of the market that wants a simpler / easier to manage solution. They need dead simple mechanism to set the SOC% and forget. WW is not there yet. but atleast they are trying something. I am sure their batteries wil work with the Satiator - but if i am reading Pushkar's post clearly, then looks like you don't necessarily need to.
No, that is not correct.Would be interesting to know how the "smarts are going to be moved into the battery", that basically means the constant current / constant voltage "charger" will be in the battery if its going to control SOC which is just the constant voltage held at the end of charge and the bulk charge current which is the max current at the beginning. This means the entire charger is in the bike as the charger rectifies mains from 120v AC to DC at SOC voltage using a switching power supply.
The BMS can pause charging the pack once the pack reaches a specific SOC. Not sure why this is confusing.If you still have a external power brick thats going from mains to say 58.8v DC for 52v batteries then it wont work with any battery out there and then you need a secondary buck power supply in the bike to cut 58.8v down to whatever final SOC your looking for say 56.6v for 85% charge.
