Carlosebermudez
Hello Internet eBike Gurus, I need your help!
I recently bought a BBSHD 48v with the 850c display and a Chamrider 48v 30Ah battery with a 40amp BMS along with their 4amp charger.
I charged the bike once to 100% and when I start the bike the display shows only a 60% charge. I rode it hard on maximum PAS on some hills for around 5 miles. The second time, I charged it to 100% overnight and left it charging until 4 pm, the display showed 62%. This time I rode it slowly, at a maximum of PAS 6 on really steep hills and between 1 and 3 for the rest of the ride. Got around 5 miles this time and the route I followed was had an 800 feet hill climb but it was only a third of the ride, the rest was flat. I noticed it starting shutting off at around 50v. Today, I got a voltmeter and measured: 54.0 volts coming out of the battery few seconds after unplugged from the charger, and 54.5 from the charger (fans off).
I'm guessing the problem is either a faulty cell or I should let it balance. So I'm keeping it plugged for 24 hours to see if the voltage rises a little. I don't know if I can balance the pack without the charger, just letting the battery sit. Or should I turn the key to the ON position to power the BMS. don't know if that would make a difference.
