Why unsafe? They do make patching a pain since the goo goes everywhere. I’ve ridden over 8,000 eBike miles, had three flats but never had to change on the road. Once I had to stop at a gas station for air to make it home. It all depends where you ride.I have been reading about the problems on the road changing tires, Are the slime sealing tubes safe and would it be recommended to replace the tubes that come with the bike (just bought new ebike with Kenda K1088 Tire 700C x 45C (45-622) ) now? thanks
So you use the slime sealing tubes?Why unsafe? They do make patching a pain since the goo goes everywhere. I’ve ridden over 8,000 eBike miles, had three flats but never had to change on the road. Once I had to stop at a gas station for air to make it home. It all depends where you ride.
Nope. Sorry I wasn’t clear with that.So you use the slime sealing tubes?
I have been running tubeless for some time now, and wish I had converted soonerHow many hare have gone tubeless since it really caught on? I have to say I’ve been very happy since losing the tubes. Had one cut that the Stan’s sealant could slow down but not seal completely, but a quick shot from a tubeless repair kit took care of it and I’ve had nothing further. I still carry a tube for last ditch emergency solution, but I really don’t worry about flats anymore.
That's pretty much it, low pressure while avoiding pinch flats. If you don't care so much about optimal offroad traction, using a tire with an integrated puncture belt and regular tube and pumping it up to 30psi or more is plenty in my experience. I still carry tools to fix a flat though.What are tubeless advantages over sliming a tube and using a protective insert? I assume it's a little lighter, and you can run lower PSI without a chance of pinch flats, but I'm still new and want to be sure I'm on the right track![]()
Just don’t EVER bring a slime tire to my little home shop and ask for the usual happy helper to fix. Messy. Real messy. But I’m on a decade long run of zero, that’s right none, not a single, not even the hint of a flat.
I haven’t had a flat in the 12 years that I’ve started riding bicycles again. I’m not a high mileage guy. 25 over the course of two days. Check my tires every other ride, a “prefilight”, and adjust. I get very good mileage and service. I do retire skins often before they wear out. Long steel stem Schraeder tubes, a little xcellent quality woven cotton rim tape. French is best for me. I guess i’m Lucky. Or my preoccupation with safety pays off.You're right, slime is messy but I have to say I've never had a flat when using slime.
