17Stratton
I'm 6'1", so probably a large.What size frame will you be ordering? M/ L/ XL ?
I will be interested to see how it looks. Can you reply with the link to the titan. Did not see it come up immediately with a Google search. Thanks Pushkar.You can actually do integrated + titan, no problem. That will be ~2000Wh. For founders I will make the upgrade price to titan reasonable .. so you dont need to buy the integrated + add on + titan.. you can just buy integrated + titan.
I would need at least 1100wh for my base case commute, especially if this motor is pulling 2300 watts continuous.
Are you really going to pull 2.3k watts continuously? That's doing what, using throttle to go something like 35MPH continuously? Maybe you should be on a scooter instead? Range decreases with increased speed.
I ride a high-power Bafang Ultra-powered eBike that maxes out at 2k watts. I'm mostly below 750 watts, except when accelerating, climbing hills, or making a speed run. I haven't done any real long rides, but so far 40 miles of riding with pedaling is like a 25%-30% drop (guessing).
What's the difference between 1 and 2? Same capacity? Hard to tell from the images how they are different.
