Aging Yuba eMundo
Dan de Angeli
Greetings. I am Dan from Boston. I use my electric Yuba eMundo for kid pick up groceries, and general schlepping. It is my non car car! Anyway the range is getting pretty low, and I am wondering if anyone out there can get 20 miles out of cargo bike and if so what are they riding. I am looking to upgrade or replace this with something that can get me downtown and back on one charge. Currently I can do about 8 miles before it wears out.//
thanks Dan de Angeli
https://photos.app.goo.gl/m8jOb4HCoxK1HHVd2
Dan, sounds like you just need a new battery or two for your bike and most likely a decent tune-up. There are several versions of electric Yubas, which motor & battery combo do you have? Some batteries can be rebuilt for a modest sum of $$ and some are less expensive to buy new given the upgrades in battery quality in the last few years. If you like the Yuba, no need to ditch it; just upgrade it.
Rather than ditching what obviously is still a perfectly good bicycle have you considered just upgrading the components? Repurposing is not a crime.
Start with this: https://lunacycle.com/bafang-bbs02-kit/
Also get a disc compatible front wheel and add a disc brake which shouldn't cost more than $250 and for $1000 or so you are where you want to be in regards to power and range and with better stopping power.
Recycle the old parts responsibly to someone on CL that wants them for cheap and voila!
(Ann and I are on kind of the same wavelength)
Not everyone is an ebike electrician either, and one might be needed here.
Dan may just need a new battery. From what I've read, Yuba doesn't sell parts or batteries for their older models, so owners have to scrounge around. It's a common battery from 3-4 years ago, and I see posts here from users trying to find something like it. They all look similar, but the plugs in the bottom might be a bit different, so unless one finds an "official" source, it could be a gamble. Dan will have to check with Yuba to see where they send their customers. If it costs $800, well that's a fair price for an exact replacement, in my opinion.
Per this manual, this cargo bike runs a 200W front Ezee motor and a 36V 10AH battery. The latter is rated 360 watt-hours. Now being a tinker and conscious of my burgeoning ebike budget, my plan would be to replace with a higher AH downtube battery for under $500 from a US vendor. By the way, any AH rating equal to or higher than the old one will suffice, but higher AH gives more range.
I would expect the wiring to consist of just cutting the existing two power wires and re-splicing to the new battery cradle. Old charger will work, but might need a new charge plug, but a charger is about $50. If the bike has mounts for water bottles on the downtube, the battery cradles attach there, but it should be augmented with hose clamps. Clamps will work if there are no mounts.
Then again, I find bike mechanics kind of fun. If I had this Yuba, I'd probably take off the display and controller and upgrade it to 48 volts. That would be about $100 in parts.
